GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
If you're looking for hyper-realistic gameplay, stunning visuals, and exceptional value, this is your graphics card.
SPECIFICATIONS
- Base Clock: 1176 MHz
- Boost Clock: 1255 MHz
- Memory Clock: 5400 MHz Effective
- CUDA Cores: 640
- Bus Type: PCI-E 3.0
- Memory Detail: 2048MB GDDR5
- Memory Bit Width: 128 Bit
- Memory Speed: 0.4ns
- Memory Bandwidth: 86.4 GB/s
KEY FEATURES
- NVIDIA® TXAA™ Technology
- NVIDIA GPU Boost 2.0
- NVIDIA® PhysX® Technology
- NVIDIA FXAA™ Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA® Surround™
- Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
- Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
- NVIDIA 3D Vision®-Ready*
- NVIDIA CUDA® Technology
- PCI Express® 3.0 Support
- OpenGL 4.4 Support
- OpenCL™ Support
- NVIDIA SHIELD™-Ready
- NVIDIA G-SYNC™-Ready
REQUIREMENTS
- 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
- PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
- Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
- Height: 4.376in - 111.15mm
- Length: 6.7in - 170.18mm
- Weight: 0.85lb
ACCESSORIES
- EVGA Driver/Software Disc
- (1) DVI to VGA Adapter
- EVGA Accessory Pack
- User Guide
G-SYNC
NVIDIA G-SYNC is groundbreaking display technology that delivers the smoothest and fastest gaming experience ever. G-SYNC's revolutionary performance is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. The result: scenes appear instantly, objects look sharper, and gameplay is super smooth, giving you a stunning visual experience and a serious competitive edge. -
This innovative technology allows gamers to push PC performance to the maximum with precise controls. GPU Boost 2.0 intelligently monitors work with even more advanced controls like GPU temperature target, overclocking, and overvoltage to ensure that the GPU works at peak performance. -
GeForce Experience
The easiest way to optimize your games and keep your drivers up to date, the GeForce Experience application automatically notifies you of driver releases from NVIDIA. With a single click, you'll be able to update the driver directly, without leaving your desktop. Plus, it offers exciting features like GeForce ShadowPlay that lets you capture and share your greatest gaming moments, automatically. -
Two anti-aliasing modes: NVIDIA FXAA and TXAA
Anti-aliasing smooths out jaggies (jagged edges) but can be demanding on frame rates. Fast approximate anti-aliasing (FXAA) is an antialiasing technology that produces beautiful, smooth lines with minimal performance impact. And with Kepler-based GPUs, you can enable FXAA in hundreds of game titles through the NVIDIA control panel. The second mode, temporal anti-aliasing (TXAA), is an in-game option that combines multisample anti-aliasing (MSAA), temporal filtering, and post processing for even higher visual fidelity. -
NVIDIA PhysX technology
Full support for NVIDIA PhysX technology enables a class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA 3D Vision-ready
NVIDIA 3D Vision brings a fully immersive, stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. -
NVIDIA Surround with up to three monitors
Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email, or web while you're gaming. -
NVIDIA adaptive vertical sync
Nothing is more distracting than framerate stuttering and screen tearing. The first tends to occur when framerates are low, the second when framerates are high. Adaptive V-Sync is a smarter way to render frames. At high framerates, V-Sync is enabled to eliminate tearing. At low frame rates, it's disabled to minimize stuttering.
- EVGA GeForce GTX 750 Ti Superclocked - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1176 MHz
- Boost Clock
- 1255 MHz
- CUDA Cores
- 640
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
- 17.018 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1176 MHz
- Boost Clock
- 1255 MHz
- CUDA Cores
- 640
- Max Resolution
- 4096 x 2160
- API Supported
- Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Bandwidth
- 86.4 GBps
- OS Required
- Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Required Power Supply
- 400 W
- Additional Requirements
- Adjacent PCI slot
- 60 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
- RoHS
- 17.018 cm
- 11.115 cm
- Limited warranty - parts and labour - 3 years
