GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
If you're looking for hyper-realistic gameplay, stunning visuals, and exceptional value, this is your graphics card.
SPECIFICATIONS
- Base Clock: 1020 MHz
- Boost Clock: 1085 MHz
- Memory Clock: 5400 MHz Effective
- CUDA Cores: 640
- Bus Type: PCI-E 3.0
- Memory Detail: 2048MB GDDR5
- Memory Bit Width: 128 Bit
- Memory Speed: 0.4ns
- Memory Bandwidth: 86.4 GB/s
KEY FEATURES
- NVIDIA® TXAA™ Technology
- NVIDIA GPU Boost 2.0
- NVIDIA® PhysX® Technology
- NVIDIA FXAA™ Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA® Surround™
- Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
- Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
- NVIDIA 3D Vision®-Ready*
- NVIDIA CUDA® Technology
- PCI Express® 3.0 Support
- OpenGL 4.4 Support
- OpenCL™ Support
- NVIDIA SHIELD™-Ready
- NVIDIA G-SYNC™-Ready
REQUIREMENTS
- 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
- PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
- Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
- Height: 4.376in - 111.15mm
- Length: 6.7in - 170.18mm
- Weight: 0.85lbs
ACCESSORIES
- EVGA Driver/Software Disc
- (1) DVI to VGA Adapter
- EVGA Accessory Pack
- User Guide
- EVGA GeForce GTX 750 Ti - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 640
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
- 17.018 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 640
- Max Resolution
- 4096 x 2160
- API Supported
- Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Bandwidth
- 86.4 GBps
- OS Required
- Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Required Power Supply
- 400 W
- Additional Requirements
- Adjacent PCI slot
- 60 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
- RoHS
- 17.018 cm
- 11.115 cm
- Limited warranty - parts and labour - 3 years
