Get the weapon of choice for gamers - the EVGA GeForce GTX 660. It takes NVIDIA Kepler-powered graphics cards to new levels of affordability while retaining class-leading performance and power efficiency, making it a must-have upgrade for today's hottest games. The EVGA GeForce GTX 660 graphics card represents the Kepler "sweet spot" for gamers - the ultimate combination of performance, power efficiency, and affordability.
Performance
- NVIDIA GTX 660
- 960 CUDA Cores
- 1072 MHz Base Clock
- 1137 MHz Boost Clock
- 85.7GT/s Texture Fill Rate
- 2048 MB, 192 bit GDDR5
- 6008 MHz (effective)
- 144.19 GB/s Memory Bandwidth
- PCI-E 3.0 16x
- DVI-I, DVI-D, HDMI, DisplayPort
Resolution & Refresh
- 240Hz Max Refresh Rate
- Max Analog : 2048x1536
- Max Digital : 2560x1600 (Dual Link DVI Only)
Kepler GPU architecture
NVIDIA's Kepler GPU architecture has been designed from the ground up not just for maximum performance in the DirectX 11 games, but optimal performance per watt. The SMX streaming multiprocessor is twice as efficient as the prior generation and the geometry engine draws triangles twice as fast. The result is world class performance and the highest image quality in an elegant and power efficient graphics card. -
NVIDIA GPU Boost
Up until now, GPUs have operated at a fixed clock speed when playing 3D games, even if they have the potential to run faster. GPU Boost intelligently monitors graphics work load and increases the clock speed whenever possible. The result is that the GPU always performs at its peak and you get the highest frame rate possible. -
NVIDIA adaptive vertical sync
Nothing is more distracting than frame rate stuttering and screen tearing. The first tends to occur when frame rates are low, the second when frame rates are high. Adaptive V-sync is a smarter way to render frames. At high frame rates, V-sync is enabled to eliminate tearing, at low frame rates; it is disabled to minimize stuttering. It gets rid of distractions so you can get on with gaming. -
NVIDIA surround with up to four monitors
Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages human peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email or web while you are gaming. -
TXAA antialiasing
Antialiasing helps to smooth out jagged lines in games. Existing techniques like MSAA are effective at removing jagged lines in still images but struggle with crawling and shimmering artifacts when the player is in motion. TXAA is an antialiasing mode that combines MSAA, temporal filtering, and post processing for the highest edge quality and minimal shimmering during gameplay. -
NVIDIA 3D Vision ready
NVIDIA 3D Vision brings a fully immersive, stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. -
NVIDIA PhysX technology
It full supports for NVIDIA PhysX technology, enabling a totally class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
- EVGA GeForce GTX 660 FTW w/ ACX Cooler - graphics card - GF GTX 660 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660
- Memory
- 2 GB GDDR5
- Core Clock
- 1072 MHz
- Boost Clock
- 1137 MHz
- CUDA Cores
- 960
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 4
- DVI-D (dual link) , HDMI , DisplayPort , DVI-I (dual link) , VGA - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
- 24.1 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1072 MHz
- Boost Clock
- 1137 MHz
- CUDA Cores
- 960
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- Bandwidth
- 144.19 GBps
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Power Supply
- 450 W
- Additional Requirements
- 6 pin PCI Express power connector
- Included Accessories
- 6 pin PCIe power cable
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 24.1 cm
- 11.115 cm
- Limited warranty - 3 years
