If you're passionate about first-person shooters like Call of Duty, massively multiplayer online games like World of WarCraft, or real-time strategy games like StarCraft II, GeForce GTX is for you. And your first step into GeForceĀ® GTX gaming is the EVGA GeForce GTX 650.
Performance
- NVIDIA GTX 650
- 384 CUDA Cores
- 1058 MHz GPU MHz Boost Clock
- 1024 MB, 128 bit GDDR5
- 5000 MHz (effective) GB/s Memory Bandwidth
- PCI-E 3.0 16x
- DVI-I, DVI-I, Mini HDMI
Resolution & Refresh
- 240Hz Max Refresh Rate
- 2048x1536 Max Analog
- 2560x1600 Max Digital
Operating System Support
- Windows 7 32/64bit
- Windows Vista 32/64bit
- Windows XP 32/64bit
Requirements
- Minimum of a 400 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 20 Amps.)
- One available 6-pin PCI-E power dongle
Product Warranty
- This product comes with a 3 year warranty. Registration is recommended. EVGA offers several warranty solutions for our customers to choose from. Please refer to the suffix of the part number and our warranty terms for details.
Kepler GPU architecture
NVIDIA's Kepler GPU architecture has been designed from the ground up not just for maximum performance in the DirectX 11 games, but optimal performance per watt. The SMX streaming multiprocessor is twice as efficient as the prior generation and the geometry engine draws triangles twice as fast. The result is world class performance and the highest image quality in an elegant and power efficient graphics card. -
NVIDIA Adaptive Vertical Sync
Nothing is more distracting than framerate stuttering and screen tearing. The tends to occur when framerates are low, the second when framerates are high. Adaptive V-Sync is a smarter way to render frames. At high framerates, V-sync is enabled to eliminate tearing, at low frame rates; it's disabled to minimize stuttering. It gets rid of distractions so you can get on with gaming. -
NVIDIA surround with up to four monitors
Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages human peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email or web while you are gaming. -
TXAA antialiasing
Antialiasing helps to smooth out jagged lines in games. Existing techniques like MSAA are effective at removing jagged lines in still images but struggle with crawling and shimmering artifacts when the player is in motion. TXAA is a ant aliasing mode that combines MSAA, temporal filtering, and post processing for the highest edge quality and minimal shimmering during gameplay. -
NVIDIA 3D vision ready
NVIDIA 3D Vision brings a fully immersive, stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. In addition, you can enjoy 3D movies and 3D digital photographs from 3D VisionLive. com in eye popping, crystal-clear quality. -
NVIDIA PhysX technology
It is full support for NVIDIA PhysX technology, enabling a totally class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
- EVGA GeForce GTX 650 - graphics card - GF GTX 650 - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 650
- Memory
- 1 GB GDDR5
- Core Clock
- 1058 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 5 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 3
- DVI-I (dual link) , DVI-D (dual link) , Mini-HDMI , VGA - with adapter
- API Supported
- DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
- 15.24 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1058 MHz
- CUDA Cores
- 384
- Max Resolution
- 2560 x 1600 at 240 Hz
- 3
- API Supported
- Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia Surround technology, TXAA, FXAA, SMX technology, NVIDIA Adaptive Vertical Sync, Kepler GPU Architecture
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 128-bit
- Bandwidth
- 80 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities
- 15.24 cm
- 11.115 cm
- Limited warranty - 3 years
