Speed up your PC experience when you upgrade from integrated graphics to the NVIDIA GeForce GT 730 dedicated card. Enjoy all your videos and pictures at HD resolutions, with faster video editing, faster photo editing, and faster web browsing compared to integrated graphics. Discover faster gaming performance than integrated graphics, making all your gameplay richer and smoother. You can even get the latest drivers and optimize game settings with a single click using GeForce Experience. The GeForce GT 730 is everything you need for a better, faster PC experience.
NVIDIA PhysX technology
Full support for NVIDIA PhysX technology, enables a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
PCI Express 2.0 support
Designed for the PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
NVIDIA adaptive vertical sync
Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. -
NVIDIA FXAA technology
Shader-based anti-aliasing technology available from the NVIDIA control panel enables ultra-fast anti-aliasing in hundreds of PC games. -
Microsoft DirectX 12 API (feature level 11_0) support
DirectX 12 API (feature level 11_0) GPU designed for ultra high performance in the latest version of Microsoft DirectX. -
NVIDIA TXAA technology
Support for new temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance. -
NVIDIA 3D vision ready
Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- EVGA GeForce GT 730 LP - graphics card - GF GT 730 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 1 GB GDDR5
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 5 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- VGA , HDMI , DVI-D (dual link)
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 14.48 cm x 6.904 cm
- 3-year warranty
- Bus Type
- Graphics Engine
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Max Resolution
- 4096 x 2160
- API Supported
- Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, x.v.Color technology, Deep Color technology, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia Temporal Anti-Aliasing Technology (TXAA)
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 64-bit
- Bandwidth
- 40 GBps
- OS Required
- Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Required Power Supply
- 300 W
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 14.48 cm
- 6.904 cm
- Limited warranty - parts and labour - 3 years
