Make your entire PC experience faster with the new NVIDIA® GeForce® GT 720 dedicated graphics card. Enjoy performance that's superior to integrated graphics in all your PC multimedia applications, including 2x faster web browsing, 5x faster video editing, and 8x faster photo editing.
Play modern games with advanced and reliable dedicated graphics. 70% faster performance than integrated graphics means a rich and smooth gaming experience. Plus, get the power to drive up to three HD displays with a single card.
GeForce GT means speed, stability, and industry-leading NVIDIA drivers. Tap into GeForce Experience™ to automatically get the latest drivers and optimize game settings with a single click.
SPECIFICATIONS
- Base Clock: 797 MHZ
- Memory Clock: 1800 MHz Effective
- CUDA Cores: 192
- Bus Type: PCI-E 2.0
- Memory Detail: 2048MB DDR3
- Memory Bit Width: 64 Bit
- Memory Speed: 1.43ns
- Memory Bandwidth: 14.4 GB/s
DIMENSIONS
- Height: 2.709in - 68.8mm
- Length: 6.6in - 167.75mm
KEY FEATURES
- NVIDIA PhysX technology
- PCI Express 2.0 support
- NVIDIA Adaptive Vertical Sync
- Microsoft DirectX 12 API (feature level 11_0) Support
- NVIDIA 3D Vision Ready*
- NVIDIA CUDA Technology
- OpenGL 4.4 Support
- OpenCL Support
- NVIDIA FXAA Technology
- NVIDIA PureVideo HD Technology
REQUIREMENTS
- 300 Watt or greater power supply with a minimum of 20 Amp on the +12 volt rail.**
- PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot.
- Windows 8 32/64bit, Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
- EVGA GeForce GT 720 - graphics card - GF GT 720 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 720
- Memory
- 2 GB DDR3
- Core Clock
- 797 MHz
- CUDA Cores
- 192
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- VGA , DVI-D (dual link) , HDMI
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- Fanless
- 16.775 cm 6.88 cm
- 3-year warranty
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 797 MHz
- CUDA Cores
- 192
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA)
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 64-bit
- Bandwidth
- 14.4 GBps
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- Required Power Supply
- 300 W
- Software Included
- EVGA Precision X, EVGA OC Scanner X
- 16.775 cm
- 6.88 cm
- Limited warranty - 3 years
