Good graphics processing is a required ingredient in the modern PC. With DirectX 10.1 support, Nvidia PhysX technology, HDMI output and Nvidia CUDA technology the EVGA GeForce 210 is an essential addition to your PC. Whether you are doing video or photo editing, gaming, HD video playback, or just looking for a Premium Windows 7 experience, the EVGA GeForce 210 brings incredible processing power, at an incredible price.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
- Microsoft DirectX 10.1 Shader Model 4.1 Support
- Nvidia PureVideo HD Technology
- PCI Express 2.0 Support
- OpenGL Support
- Dual-Link HDCP Capable
- Nvidia CUDA Technology
- Microsoft Windows XP/Vista/7 Support
- Nvidia PhysX Ready Technology
- OpenCL Support
- 3 Year Manufacturers Warranty
Spec
- Core Clock: 520 MHz
- Memory Clock: 1200 MHz Effective
- Shader Clock: 1238 MHz
- CUDA Cores: 16
- Bus Type: PCI-E 2.0
- Memory Detail: 1024MB DDR3
- Memory Bit Width: 64 Bit
- Memory Bandwidth: 9.6 GB/s
- (1) DVI, (1) HDMI and (1) VGA Connector
- Warranty: 3 Year Manufacturers Warranty
DVI-I output
Digital video interface - integrated - supports both VGA and digital signals. -
Second generation Unified Shader Architecture
The Unified Shader Architecture technology offers 50% more performance through 240 enhanced processing cores. -
NVIDIA CUDA support
Accelerates CUDA based applications through the GPU's processing power allowing for faster application performance such as video transcoding. -
NVIDIA PhysX ready
Enjoy more visual immersion with life like physics for a more dynamic experience. -
NVIDIA PureVideo HD technology
Smooth video, accurate colors, precise image scaling, video decode acceleration and post processing, all provided by the graphics card to give you the best HD experience possible.
- EVGA GeForce 210 - graphics card - GF 210 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce 210
- Memory
- 1 GB DDR3
- Core Clock
- 520 MHz
- Effective Memory Clock
- 1.2 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- DVI-I (dual link) , HDMI , VGA
- API Supported
- OpenGL 3.1, OpenCL, DirectX 10.1
- 16.8 cm x 6.9 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 520 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600 at 240 Hz
- API Supported
- Fanless heatsink, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.2 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- Software Included
- Drivers & Utilities
- 16.8 cm
- 6.9 cm
- Limited warranty - 3 years
