Robust and flexible
Thanks to Epson's fast drying DURABrite Ultra Ink, business documents are water, smudge and highlighter resistant. Cartridges are also available in XL size, helping to save further on costs. XL inks are ideal for high print volumes, offering up to a 50 percent lower cost-per-page than competitive lasers(1).
Business-quality printing at up to 15ppm for single-sided documents and 7.9ppm for double-sided documents(2), ensure work is delivered quickly and efficiently every time.
This device allows users to load up to 250 sheets of A4 plain paper. It has a single-sheet rear-feed paper tray providing media flexibility, accepting varied paper types and thicknesses, such as card, envelopes and business cards. With a duplex ADF for multi-page scanning, copying and faxing, this printer provides everything a small office or workgroup needs, in one compact device.
Epson Connect(3) allows users to print wirelessly from smartphones and tablet PCs within the office and print from anywhere in the world by emailing documents directly to the printer's unique email address. The Remote Printer Driver offers more flexibility to print from a PC to any Epson Connect printer anywhere in the world, while Scan-to-Cloud enables users to store scanned documents directly in Cloud services. In addition the WF-3520DWF is Apple AirPrint and Google Cloud print ready.
Wi-Fi 4-in-1
Print, scan, copy and fax with ADF
Fast print speeds
Print up to 15 pages per minute(2)
Flexible connectivity
Wi-Fi and Ethernet
Easy-to-use
6.3cm LCD screen
Epson Connect
Freedom to print and scan anywhere
- For more information, please visit www.epson.eu/inkjetsaving
- Determined in accordance with ISO/IEC 24734 showing the average of ESAT from the Office Category Test for default simplex and duplex. For more information, please visit www.epson.eu/testing
- Requires a wireless connection to the internet. For more information, supported languages and devices please visit www.epsonconnect.eu
- For more information, please visit www.epson.eu/testing
- The maximum number of printed pages per month based on the performance capabilities of the printer, including ISO rated print speeds and paper handling capabilities
- Adaptor required (not supplied in box)
World's fastest all-in-one
Get black text documents fast, without compromising quality. -
Fast, high-quality printing and copying
Quickly print or copy documents and photos - get sharp text and vivid, true-to-life color. -
Automatic two-sided printing
Save up to 50% on paper with the option of automatic two-sided printing. -
Mobile printing
Print remotely from anywhere. Plus print from popular mobile devices. -
2.5" LCD
Use the 2.5" LCD to preview, edit and print photos, without turning on your computer.
- Epson WorkForce WF-3520DWF - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 12000 impressions
- Max Printing Speed
- Up to 15 ppm (mono) / up to 9.2 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card
- Power
- AC 230 V
- 44.9 cm x 41.7 cm x 24.3 cm
- 9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- 12000 impressions
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Printing
- Nozzle Configuration
- 384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 180 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
- Automatic redialing, colour faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 250 sheets
- 250 sheets
- 1 sheet
- Input tray - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 1 sheet , ADF - 30 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 95 g/m²
- Speed Details
- Printing: up to 38 ppm - B/W , Printing: up to 38 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 9.2 ppm - colour (ISO/IEC 24734) , Printing: up to 7.9 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 5.7 ppm (A4) - colour duplex (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- WEP, WPA-PSK
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later
- Software Included
- Epson Event Manager, Epson Easy Photo Print, EpsonNet Setup Manager, Epson Fax Utility, Presto! PageManager 9
- Voltage Required
- AC 230 V
- 17 Watt
- Power Consumption Standby
- 6.2 Watt
- Power Consumption Sleep
- 2 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60950-1, TBR21, EN 300 328, EN 301 489-1, EN 301 489-17
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 44.9 cm
- 41.7 cm
- 24.3 cm
- 9 kg
- Shipping Width
- 53.4 cm
- Shipping Depth
- 48.8 cm
- Shipping Height
- 32.8 cm
- Shipping Weight
- 11.2 kg
- Sound Emission
- 39 dBA (operating)
