Small business and home office users should look no further than the compact 4-in-1 WF-2660DWF, which offers double-sided, business quality printing and a high-yield black ink cartridge. Complete with color LCD touchscreen, the WF-2660DWF boasts Wi-Fi and Wi-Fi Direct as well as NFC, and compatibility with Epson Connect. Apple AirPrint and Google Cloud Print are also supported.
Business quality
This 4-in-1 printer uses a PrecisionCore printhead to ensure top quality, laser-like performance. Fast print speeds and a 30-page automatic document feeder for multi-page 1200dpi scanning, copying and faxing offer the ultimate in convenience. Wi-Fi, Wi-Fi Direct and Ethernet connectivity ensure the flexibility every small business needs. -
Low running costs
The WF-2660DWF is compatible with the 16XXL black ink cartridge for high-yield printing, reaching up to 1,000 pages per cartridge. Automatic double-sided printing helps save on paper costs. -
Mobile printing
Epson Connect compatibility offers useful features like scan-to-cloud, email print and the Epson iPrint. The WF-2660DWF lets you print seamlessly from smartphones and tablets. -
Tap to connect
Android smartphones equipped with NFC can connect to the printer by simply by tapping them together - what could be easier? -
Easy to use
Automatic Wi-Fi set-up helps make connection a breeze, while the 150-sheet front-loading paper cassette makes refilling easy. A 6.8cm color LCD touchscreen and a user-friendly interactive menu makes navigating the WF-2660DWF simple and quick.
- Epson WorkForce WF-2660DWF - multifunction printer - colour - with Epson 16XXL (black)
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 3000 pages
- Max Printing Speed
- Up to 13 ppm (mono) / up to 7.3 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 30 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to Cloud
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 36 cm x 23 cm
- 6.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Bundled with
- Epson 16XXL (black)
- Fax Type
- Plain paper
- Ink-jet - colour
- 3000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Bundled with
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 128 nozzles (per colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.3 pl
- Printer Drivers / Emulations
- EPSON ESC/P Raster
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Automatic redialing, colour faxing
Document & Media Handling
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 95 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 150 sheets
- 30 sheets
- Input tray - 150 sheets , ADF - 30 sheets , Output tray - 30 sheets
- Speed Details
- Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 7.3 ppm - colour (ISO/IEC 24734) , Scanning: up to 3 ipm (A4) - B/W , Scanning: up to 3 ipm (A4) - colour , Scanning: 12 sec (A4) - B/W , Scanning: 27 sec (A4) - colour
- 1 x USB 2.0 , 1 x LAN - RJ-45
- WEP, WPA-PSK, TKIP, AES
- Operating System Support
- MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, Windows 8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits)
- Software Included
- Epson Event Manager, EPSON Scan, Epson Easy Photo Print, EpsonNet Setup Manager, Epson Fax Utility, Presto! PageManager 9
- Voltage Required
- 14 Watt
- Power Consumption Standby
- 4.7 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- 42.5 cm
- 36 cm
- 23 cm
- 6.7 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.96 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.23 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
