Epson WorkForce Pro WF-5110 DW A4 Colour Printer
Quicklinx: 9C26WS00 Mfr#: C11CD12301BY
Low running costs
The WorkForce Pro WF-5110DW has an up to 50 percent lower cost per page than competitive colour lasers , saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages . And there are fewer parts to replace than a laser.
Ecological
The WF-5110DW uses up to 80 percent less power than competitive colour lasers thanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient business printer is faster than a laser on typical print jobs , with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both . Its high paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Print securely with Email Print for Enterprise. Epson Connect5 lets you easily print from smartphones, tablets and more, and its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router.
  • Ecological and low-cost A4 printer
    Small to medium offices can cut printing costs by up to 50% and energy use by up to 80% with this A4 printer, while enhancing productivity.
  • Environmentally-friendly and low-cost A4 printing
    A small workgroup printer, perfect for businesses that have traditionally used lasers and want to cut costs, increase productivity and reduce downtime, while also reducing their environmental impact. Epson's clean technology helps create a more environmentally-friendly workplace.
  • Low running costs
    For cost-conscious offices this business printer has significant advantages over comparable colour laser printers. The high-yield ink cartridges help the WF-5110DW to achieve an up to 50 percent lower cost per page than competitive colour laser printers . It uses Epson's DURABrite Ultra inks, in high-capacity ink cartridges of up to 4,000 pages , which ensure efficiency and productivity.
  • Ecological
    This printer uses up to 80 percent less power than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser.
  • Enhance productivity
    Focused on keeping offices productive, the WorkForce Pro WF-5110DW is faster than competitive colour lasers on typical print jobs , as there is no warm up time needed. It delivers fast and efficient business printing, and is capable of print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speeds in both . It has a high paper capacity of up to 580 sheets, including a second optional 250-sheet tray, meaning that less time is spent refilling.
  • Easy to use
    The 5.6cm mono LCD mono screen allows for easy control of the main functions. Automatic double-sided duplex printing as standard makes any job easy and means less paper is used too. In addition, front-loading ink cartridges are easy to change.
  • PrecisionCore
    PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the WF-5110DW's use of PrecisionCore that aids high-speed printing and enables the rear feed to be used for printing on thicker card, envelopes and labels. And it has a high monthly duty cycle of up to 35,000 pages4.
  • Built for business
    Its flexible connectivity allows this printer to seamlessly integrate into office networks. Wi-Fi, Wi-Fi Direct and Gigabit Ethernet help help to boost office productivity.
  • Print from anywhere
    Stay connected and productive. Email Print for Enterprise5 allows you to securely send documents directly to the printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
Epson WorkForce Pro WF-5110DW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
11.3 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 34 ppm - B/W , Up to 30 ppm - colour , Up to 20 ppm - B/W (ISO/IEC 24734) , Up to 20 ppm - colour (ISO/IEC 24734) , Up to 11 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 11 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Language Simulation
EPSON ESC/P Raster, Windows GDI driver
Media Type
Envelopes, plain paper
Total Media Capacity
330 sheets
Media Handling
250-sheet input tray, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
35000 pages
Print server
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition
46.1 cm x 44.2 cm x 28.4 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
2.8 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wired
AirPrint Enabled
4800 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Language Simulation
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
330 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 80 sheets
Max Media Capacity
580 sheets
Output Trays Capacity
150 sheets
Duty Cycle
35000 pages
Print server
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
SSL, WEP, IPsec, 802.1x, TKIP, AES, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
24 Watt
Power Consumption Stand by
5.5 Watt
Power Consumption Sleep
1.6 Watt
Software Included
Drivers & Utilities
Sound Emission (Operating)
51 dBA
46.1 cm
44.2 cm
28.4 cm
11.3 kg
Ink (11)
9C26 Epson T7891 XXL Black Print Cartridge In Stock £49.60
9C26 Epson T7892 XXL Cyan Ink Cartridge In Stock £56.03
9C26 Epson T7893 XXL Magenta Print Cartridge In Stock £55.99
9C26 Epson T7894 XXL Yellow Ink Cartridge In Stock £56.52
9C26 Epson 79XL Black Ink Cartridge In Stock £34.29
9C26 Epson 79XL Cyan Ink Cartridge In Stock £31.43
9C26 Epson 79XL Magenta Ink Cartridge In Stock £31.43
9C26 Epson 79 Black Ink Cartridge In Stock £19.33
9C26 Epson 79 Cyan Ink Cartridge In Stock £18.06
9C26 Epson 79 Magenta Ink Cartridge In Stock £18.06
9C26 Epson 79 Yellow Ink Cartridge In Stock £18.02
Other bundles (1)
9C26 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
