High-speed scanner
The DS-520N has a compact footprint and high-speed scanning of up to 30ppm / 60ipm, even at 300dpi in both color and monochrome. This, combined with hardware JPEG compression, makes large scan jobs faster to process. With the Network Interface Unit, it is ideal for sharing across office and department networks.
Document workflow
Epson Document Capture Pro software¹ makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document repositories. Benefit from Push Scanning with pre-defined job profiles. In addition, barcode recognition and Zonal OCR will help automate large document processes, such as file naming and folder creation. It's easy to integrate thanks to TWAIN, ISIS and WIA driver support.
Efficient
Epson 's scanning software offers a wide range of advanced document imaging features, including multi-document size detection, text enhancement and automatic de-skew to improve efficiency and increase productivity.
Network sharing}
Easily integrate this network-ready model into your company environment. Combined with Document Capture Pro/Pro Server¹, this scanner increases productivity with customisable PushScan functions from the scanner panel such as scan-to Microsoft SharePoint and cloud services.
A4 networked scanner
This high-speed sheet-fed scanner has network capability and Document Capture Pro for automatic distribution to document management systems.
- Epson WorkForce DS-520N - document scanner - desktop - USB 2.0, Gigabit LAN
- Document scanner - desktop
- Interface Type
- Light Source
- LED
- Additional Functions
- Email, scan to network share, scan to FTP
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 30 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 216 mm x 914 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8
- 29.7 cm x 15.2 cm x 15.4 cm
- 2.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 30 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Duty Cycle
- Scanner Speed Details
- 30 ppm - black & white - A4 - 300 dpi , 60 ipm - duplex - black & white - A4 - 300 dpi , 30 ppm - colour - A4 - 300 dpi , 60 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Ultrasonic multifeed sensor, A3 stitching
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 914 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B , Gigabit LAN
- Included Accessories
- Network interface panel
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Consumption Operational (Standby)
- 18 Watt
- Power Consumption Stand by
- 16 Watt
- Software Included
- Drivers & Utilities, EPSON Scan, Presto! BizCard 6, EPSON Document Capture Pro, Presto! BizCard 7
- OS Required
- 29.7 cm
- 15.2 cm
- 15.4 cm
- 2.9 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission
- 62 dBA
