The Epson Perfection V750 Photo is the ideal scanner for photo enthusiasts and advanced amateur photographers. Featuring Epson's unique Dual Lens System combined with DIGITAL ICE Technologies it delivers exceptional quality film and photo scanning.
- Epson Perfection V750 Pro - flatbed scanner - desktop - USB 2.0, FireWire
- Flatbed scanner - desktop
- Interface Type
- USB 2.0, FireWire
- Scanning Sensor Type
- CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 216 x 297 mm
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- Optical Resolution
- 6400 dpi x 9600 dpi
- Interpolated Resolution
- 12800 dpi x 12800 dpi
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Transparencies, plain paper, film
- Document Feeder Type
- Manual
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 Professional / XP Professional, Apple MacOS X 10.2 or later, Microsoft Windows XP Professional x64 Edition
- Microsoft Certification
- Certified for Windows Vista
- 30.8 cm x 50.3 cm x 15.3 cm
- 6.6 kg
- Interface Type
- USB 2.0, FireWire
- 216 x 297 mm
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 48-bit colour
- Scan Mode
- Single-pass
- CCD
- Bulb / Light Source Type
- Scan Density Range
- 4.0D
- Scanner Speed Details
- 11 sec/scan - black & white - A4 - 300 dpi , 12 sec/scan - colour - A4 - 300 dpi , 20 sec/scan - colour - A4 - 600 dpi , 35 sec/scan - film (negatives) - 35mm - 2400 dpi , 36 sec/scan - film (positives) - 35mm - 2400 dpi
- Scanner Features
- Digital ICE Technology, Dual Lens System
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Manual
- USB - Type B , FireWire - 6 pin FireWire
- Included Accessories
- Transparency adaptor, film holder
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 32 Watt (19 Watt)
- Software Included
- SilverFast Ai 6, Adobe Photoshop Elements 3.0, ABBYY FineReader 6.0 Sprint Plus
- OS Required
- 30.8 cm
- 50.3 cm
- 15.3 cm
- 6.6 kg
- 5 °C
- 35 °C
- 10 - 80%
Customer reviews
Write a review for the Epson Perfection V750 Pro here!
Excellent results but V700 much cheaper
Reviewed by Steve. Review Posted 28/09/2007
I bought the V750 pro to allow me to scan negatives mainly as it allows you to use fluid mounts so that you get better scans but I found that it's not that easy to get rid of the tiny air bubbles. It took ages to get good quality scans using the fluid mounts and I regret not buying the much cheaper V700 that, as far as I can see, only misses out on the liquid mount option. Excellent scanning otherwise but I'd recommend the V700 as a better buy.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
