Epson Lamp for EB-G5200W/G5300/G5350
Quicklinx: 580VWS00 Mfr#: V13H010L46
The genuine Epson ELPLP46 ultra high efficiency (UHE) projector lamp is designed as a replacement projector lamp for the Epson PowerLite Pro G5200WNL and G5350NL Projectors.
The ELPLP46 replacement projector lamp is rated at 230W. The lamp is user-replaceable. Lamp module can be installed whether projector mounted on the ceiling or sitting on a tabletop; refer to your projector's manual for installation instructions for this replacement lamp.
Epson projector lamp
Projector lamp
Epson EB-G5200WNL, EB-G5350NL
Projector lamp
