Epson FX 2190N Mono Dot-Matrix Printer
Quicklinx: 5JLWWS00 Mfr#: C11C526023A0
This wide carriage printer combines high speed printing with outstanding reliability.
A mean volume between failure of 52 million lines makes this printer suitable for medium and large print volumes. The paper can be fed from the front, top, rear or bottom and an optional additional push/pull tractor unit can store a second continuous form, which is ideal for commercial and industrial environments.
Epson FX 2190N - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
9.4 kg
Max Media Size
364 x 420 mm, continuous paper 102 mm - 406 mm (width)
Max Media Size (Custom)
420 mm x 364 mm
Print Speed
Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 559 char/sec - fast draft , Up to 627 char/sec - fast draft , Up to 419 char/sec - draft , Up to 503 char/sec - draft , Up to 104.6 char/sec - near letter , Up to 125.9 char/sec - near letter
Parallel, USB, LAN
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P, IBM PPDS
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Monthly Duty Cycle (max)
23000 pages
Print server - Ethernet, Fast Ethernet - plug-in module
Microsoft Certification
Works with Windows Vista
1-year warranty
58.9 cm x 35 cm x 16.8 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 680 char/sec - max speed - 12 cpi , Up to 566 char/sec - max speed - 10 cpi , Up to 559 char/sec - fast draft - 10 cpi , Up to 627 char/sec - fast draft - 12 cpi , Up to 419 char/sec - draft - 10 cpi , Up to 503 char/sec - draft - 12 cpi , Up to 104.6 char/sec - near letter - 10 cpi , Up to 125.9 char/sec - near letter - 12 cpi
Wired
Parallel, USB, LAN
Language Simulation
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
420 mm x 364 mm
Media Sizes
Envelope Sizes
US No 10 (104.7 x 241.3 mm), US No 6 (92 x 165 mm)
Max Sheets in Multi-Part Form
6
Duty Cycle
23000 pages
Print server - plug-in module
1 x parallel , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
MTBF
20,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
53 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
55 dBA
58.9 cm
35 cm
16.8 cm
9.4 kg
5JLW Epson Black Fabric Ribbon for FX2190 In Stock £10.24
Resources
The following resources are available for the Epson FX 2190N Mono Dot-Matrix Printer
