Efficient & affordable
Utilising Epson's Claria Home Inks, this small-in-one is ideal for producing crisp, clear text and glossy, lab-quality photos. Individual ink cartridges mean only the colour used needs to be replaced to save on costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people, the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
PC-free printing
Simply slot in a memory card and use the 3.7cm colour LCD screen and helpful menu prompts to print your photos without a PC.
Space saving
Stylish and compact - the XP-335's small and lightweight design means it doesn't take up much valuable desk space.
Compact Wi-Fi small-in-one
Save space, money and time with this Epson small-in-one, featuring individual inks, mobile printing and LCD screen.
- Epson Expression Home XP-335 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 9 ppm (mono) / up to 4.5 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Connection Availability
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card
- Power
- AC 230 V
- 39 cm x 30 cm x 14.5 cm
- 4.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
- Ink Type
- Epson Claria Home Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets
- Speed Details
- Printing: up to 9 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
- Software Included
- Epson Easy Photo Print
- Voltage Required
- AC 230 V
- 13 Watt
- Power Consumption Standby
- 1.6 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- 39 cm
- 30 cm
- 14.5 cm
- 4.2 kg
- Sound Emission
- 36 dBA (operating)
Epson XP235/332/335/432/435 Multipack XL Ink Cartridge | In Stock | £64.74 |
Epson XP235/332/335/432/435 Magenta Ink Cartridge | In Stock | £7.73 |
Epson XP235/332/335/432/435 Yellow Ink Cartridge | In Stock | £7.73 |
Epson XP235/332/335/432/435 Multipack Ink Cartridge | In Stock | £35.16 |
Epson XP235/332/335/432/435 Black Ink Cartridge | In Stock | £19.96 |
Epson XP235/332/335/432/435 Yellow Ink Cartridge | In Stock | £14.78 |
Epson XP235/332/335/432/435 Cyan Ink Cartridge | In Stock | £7.73 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £13.79 |
