Epson Expression Home XP-312 Colour Inkjet Multifunction Printer
Quicklinx: 8WZQWS00 Mfr#: C11CC92301
The Expression Home XP-312 is part of the Small-in-One range - Epson's smallest-ever range of all-in-one home inkjets. This printer, scanner and copier offers cost-effective printing for home users looking for Wi-Fi connectivity, LCD screen and mobile printing. It also offers the added benefit of Wi-Fi Direct for easy printing without a wireless network .
  • Print, copy, scan
  • Four Individual inks
  • Wi-Fi
  • iPrint connectivity
  • Email print, Airprint, Google Cloud Print, Wi-Fi Direct
Epson Expression Home XP-312 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 8.7 ppm (mono) / up to 4.5 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card
AC 120/230 V (50/60Hz)
39 cm x 30 cm x 14.5 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
USB, Wi-Fi
AirPrint Enabled
Supported Flash Memory
SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 8.7 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec (10 x 15 cm (4"x6")) - photo
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later, Windows 8
Software Included
Epson Event Manager, Epson Easy Photo Print, Epson Connect
13 Watt
Power Consumption Sleep
2.7 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
39 cm
30 cm
14.5 cm
4.2 kg
8WZQ Epson A4 Iron On Transfer Pack 10sht In Stock £13.27
8WZQ Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
