Efficient & affordable
Epson's Claria Home Ink is ideal for affordable and reliable printing, producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money.
Easy set-up
The automatic Wi-Fi set-up makes configuring laptops and computers to print and scan wirelessly extremely easy. You don't need to know your network settings, as the XP-225 automatically finds the relevant connection settings to configure itself.
Mobile printing
The XP-225 comes with Epson Connect which consists of Epson iPrint – for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer.
Simple to maintain
Claria Home Ink cartridges are available in standard and XL sizes. Identifying the right ink cartridge for your printer couldn't be simpler – just look out for the Daisy image.
Epson's Claria Home Ink is ideal for affordable and reliable printing, producing crisp, clear text documents and glossy, lab-quality photos. With individual ink cartridges you only have to replace the colour used, saving you money. -
Easy set-up
The automatic Wi-Fi set-up makes configuring laptops and computers to print and scan wirelessly extremely easy. You don't need to know your network settings, as the XP-225 automatically finds the relevant connection settings to configure itself. -
Mobile printing
The XP-225 comes with Epson Connectwhich consists of Epson iPrint– for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. -
Simple to maintain
- Epson Expression Home XP-225 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 6.2 ppm (mono) / up to 3.1 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from memory card
- Power
- AC 230 V (50/60Hz)
- 39 cm x 30 cm x 14.5 cm
- 3.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 128 nozzles (black), 3 x 42 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
- Ink Type
- Epson Claria Home Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 90 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 50 sheets
- Input tray - 50 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 6.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 3.1 ppm - colour (ISO/IEC 24734) , Printing: up to 26 ppm - B/W , Printing: up to 13 ppm - colour , Printing: 54 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, TKIP, AES
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
- Software Included
- Epson Easy Photo Print
- Voltage Required
- 11 Watt
- Power Consumption Standby
- 4.2 Watt
- Power Consumption Sleep
- 1.6 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B, UL 60950-1, EN 60950-1, EN 300.489.1, EN 300 328, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- ENERGY STAR Certified
- 39 cm
- 30 cm
- 14.5 cm
- 3.9 kg
- Shipping Width
- 45.8 cm
- Shipping Depth
- 36.8 cm
- Shipping Height
- 19.6 cm
- Shipping Weight
- 4.84 kg
- Sound Emission
- 53 dB (operating)
- 10 °C
- 35 °C
- 5 - 85% (non-condensing)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.96 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.23 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £14.09 |
