Bright big screen experience
You can watch bright content with accurate colours in a wide variety of light levels, without having to sit in the dark. This is thanks to an equally high White and Colour Light Output of 3,000lm and Epson's 3LCD technology. In addition, the contrast ratio of 12,000:1 also means that very dark, shadowy movie scenes or live action sport events appear clearer and don't look washed out.
Easy to use
The projector is quick and simple to set up, thanks to its manual horizontal slider and automatic vertical keystone correction. Whatever the angle of the actual projector, you can align the projection to ensure a straight and correct image; great for settling down to a film, arranging online games quickly or making sure you don't miss the start of important sporting events.
Portable projector
With its slim, lightweight design, and included carry case, you can easily transport the projector and take the big screen experience wherever you want - whether it's in a different room or at a friend's house.
HD-Ready 3LCD projector
Transform video games, movies and sports into big screen events with cinematic-quality images thanks to this HD-Ready projector.
- Epson EH-TW490 - 3LCD projector - portable
- 3LCD projector - 720p
- Brightness
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 12000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- S-Video
- Speakers
- Speaker(s) - integrated
- 29.7 cm x 23.4 cm x 7.7 cm
- 2.4 kg
- 2-year warranty
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 12000:1 (dynamic)
- Image Size
- 84 cm - 808 cm
- Projection Distance
- 0.9 m - 10.8 m
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- 200 Watt
- Bulb life cycle
- Auto Vertical Keystone, EPSON 3LCD technology, 16:10 aspect ratio support, Game mode, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- S-Video
- Video Interfaces
- HDMI, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- Included Accessories
- Carrying case, wireless remote control
- Security Features
- 29.7 cm
- 23.4 cm
- 7.7 cm
- 2.4 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 2000 hours
- 5 °C
- 35 °C
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
