Ultra-mobile, extra-flat: Presenting on the move has never been easier, thanks to the lightweight design. Weighing just 1.7kg, this is the ideal projector for anyone travelling to meetings.
Go wireless: With inclusive high-speed Wi-Fi functionality, setting up a presentation is a smooth, simple process minus the bother of cables.
Enhance your presentation: Once connected, presentations can be controlled and improved with a host of Easy MP features including; 3-in-1 USB display - compatible with Macs as well as PCs, USB plug and play flash drive and multi-screen display where users can connect up to four projectors from a single computer.
Get a wider picture: See more of the presentation with the WXGA resolution. Ideally suited to spreadsheets and data, audiences will see everything displayed on a widescreen computer as this format offers 30% more pixels than XGA.
First-class picture quality: Audiences will enjoy perfect picture quality, impressive natural colours and brightness of 3,000 lumens white and Colour Light Output (CLO), thanks to Epson's 3LCD technology.
Speedy start-up: Simple to set up with features such as quick-start and instant-off.
Straighten up: Slides and images can be aligned and distortion corrected with the projector's automatic vertical and horizontal keystone correction. Projected images fit into any projection screen with a black frame with the Screen Fit function, exclusive to the EB-1776W. And with no placement constraint, you can set up the projector anywhere (not exactly anywhere) in the room and your image will be automatically adjusted to fit the screen.
Ultra-mobile projector for business presentations
A top-of-the-range, ultra-mobile, wireless WXGA projector for business users, combining superb image quality, brightness and simple set-up with a range of Easy MP features.
- Epson EB-1776W - 3LCD projector - portable - 802.11g/n wireless
- 3LCD projector
- Networking
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Brightness
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- UHE 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11g/n wireless
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- 304 Watt
- 29.2 cm x 21 cm x 4.4 cm
- 1.7 kg
- 3-year warranty
- 3LCD projector
- Networking
- 802.11b/g/n
- Data Link Protocol
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.7 m - 8.2 m
- Throw Ratio
- 1.04 - 1.26:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- UHE 230 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
- EPSON 3LCD technology
Lens
- Focus Type
- Powered
- Lens Aperture
- F/1.58-1.7
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 1080p
- LAN and Wireless Image Transferring Protocols
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case, USB wireless network adapter, Quick Wireless Connection USB Key, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- 304 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- 29.2 cm
- 21 cm
- 4.4 cm
- 1.7 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- Sound Emission
- 40 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
