EE 4G Car WiFi Mobile Broadband 2GB - 3 Month
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: C6ZVWS00 Mfr#: 300014833
Stream your favourite shows from the backseat
New 4GEE WiFi designed for the car gives internet access to everyone you're travelling with, letting the driver keep their eyes on the road.
It allows passengers to check their newsfeeds, stream music, play online games and watch films or TV programmes - making car journeys much more fun for everyone. Car WiFi on the EE network. It's a game changer.
Plenty for everyone
Car WiFi makes car journeys more fun and entertaining for everyone you're travelling with. Designed specifically to be used in the car, it plugs into your 12 volt power socket which means it'll never run out of power and you don't need to remember to recharge it.
Car WiFi from EE supports up to 10 WiFi enabled devices at once (like tablets and laptops), so everyone in the car can go online at the same time.
WHAT'S IN THE BOX?
  • Device
  • Keep Me Card
  • Keep Me Card Stickers
  • Quick Start Guide
  • Safety Info Leaflet
DIMENSIONS
Size: 59mm × 49mm × 88mm
Weight: 50g
  • Fill up your car with the Internet
    The Buzzard 2 from EE is a 4GEE Wi-Fi designed to plug directly into your car's dashboard, with an intuitive lighting system that makes it easier to use. The look features a brushed metal effect, making it a welcome addition to any car interior - and it also acts as a USB adaptor, so now you can charge your tablet or phone while streaming 4GEE. Don't forget to look out for the free monthly data packages - there's plenty for occasional weekend use, and plenty more if you need it.
  • Plenty for everyone
    Car Wi-Fi makes car journeys more fun and entertaining for everyone you're traveling with. Designed specifically to be used in the car, it plugs into your 12 volt power socket which means it'll never run out of power and you don't need to remember to recharge it. Car Wi-Fi from EE supports up to 10 Wi-Fi enabled devices at once (like tablets and laptops), so everyone in the car can go online at the same time.
EE Buzzard 2 - mobile hotspot
Size
59mm x 49mm x 88mm
50g
Data Value
2GB per month x 3 months
CPU
Balong 720M
Internal Memory
128.0MB
CPU Speed
667.0 Mhz
Wi-Fi
802.11 b/g/n
Bluetooth
None
