Wireless 802.11n Access Point
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes.
Universal Repeater Mode
The Universal Repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools.
Robust Wireless Security with WPA and WPA2
Except for the basic security control by ESSID and 64/128 bit key length WEP encryption, this access point also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hidden ESSID. It provides a total solution for you to build up a secure wireless network environment that can prevent from all kinds of hacker intrusion.
Web Configuration
You can configure this access point through the friendly Web user interface with a browser.
Wireless 802.11n access point
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes. -
Universal repeater mode
The universal repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools…etc. -
Robust wireless security with WPA and WPA2
Except for the basic security control by ESSID and 64/128 bit key length WEP encryption, this access point also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hidden ESSID. It provides a total solution for you to build up a secure wireless network environment that can prevent from all kinds of hacker intrusion. -
Web configuration
- Edimax EW-7416APn - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- RAM
- 16 MB
- Flash Memory
- 4 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- Frequency Band
- 2.4 GHz
- OS Required
- Microsoft Windows 95/98, Microsoft Windows 2000 / ME / XP/ Vista
- 12.7 cm x 9.6 cm x 3 cm
- 12.7 cm
- 9.6 cm
- 3 cm
Processor / Memory / Storage
- RAM
- 16 MB SDRAM
- Flash Memory
- 4 MB
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- DHCP support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft)
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 3 dBi
- 1 x 100Base-TX - RJ-45
- FCC, RoHS
- Power Device
- External power adapter
- OS Required
- 10 °C
- 40 °C
- 10 - 90%
Customer reviews
Write a review for the Edimax Wireless-N (802.11n) Range Extender here!
Why can't all networking be this simple?
Reviewed by Anonymous Review Posted 09/04/2011
Why can't all networking be this simple? Up and running in about 2 minutes :)
- Overall
- Ease of use
- Value for money
Low cost, simple and easy to use
Reviewed by Peter. Review Posted 15/07/2009
Having spent the best part of a day trying to configure a Linksys G router to talk with my Belkin Modem/Router without any success, I was fortunate to come across this range extender in my search.
There are not too many other N range extenders out there and reviews for other extenders all define how poor they are to set up.
Within 15 minutes of opening up the box, it was connected, configured and working perfectly.
The range is great, and now I have full access to the internet and network from my remote computer in the office in the garden.
- Overall
- Ease of use
- Value for money
Superb
Reviewed by DT. Review Posted 24/04/2009
Couldn't agree more with the other reviews. Great little device, achieves all that it says and not many products give you that!
"Not only are they extenders, but access points, bridges and more."
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
