Your basket is empty
Edimax Wireless-N (802.11n) Range Extender
Customer rating: 5.0* (Write a review)
Quicklinx: 5BR5WS00 Mfr#:
  • IEEE 802.11n (draft)
PC Pro logo
Wireless 802.11n Access Point
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes.
Universal Repeater Mode
The Universal Repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools.
Robust Wireless Security with WPA and WPA2
Except for the basic security control by ESSID and 64/128 bit key length WEP encryption, this access point also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hidden ESSID. It provides a total solution for you to build up a secure wireless network environment that can prevent from all kinds of hacker intrusion.
Web Configuration
You can configure this access point through the friendly Web user interface with a browser.
  • Wireless 802.11n access point
  • Universal repeater mode
    The universal repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schoolsetc.
  • Robust wireless security with WPA and WPA2
  • Web configuration
Edimax EW-7416APn - radio access point
Radio access point
External
RAM
16 MB
Flash Memory
4 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Frequency Band
2.4 GHz
Microsoft Windows 95/98, Microsoft Windows 2000 / ME / XP/ Vista
12.7 cm x 9.6 cm x 3 cm
Radio access point
12.7 cm
9.6 cm
3 cm
Processor / Memory / Storage
RAM
16 MB SDRAM
Flash Memory
4 MB
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
DHCP support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft)
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
3 dBi
1 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
10 °C
10 - 90%
Customer reviews
Write a review for the Edimax Wireless-N (802.11n) Range Extender here!
Why can't all networking be this simple?
Reviewed by Anonymous Review Posted 09/04/2011
Why can't all networking be this simple? Up and running in about 2 minutes :)
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The simplest thing I've ever intalled!
Reviewed by Anonymous Review Posted 11/01/2011
This has helped extend the range of my BT Homehub and was esay to install, though I think the intructions may be out of date.
I simply attached a network cable from the device to the humehub, ran the CD, and the wizard helped me through the process. To be honest, all you need to do is select the option for range extender and it does the rest.
Then I unpluggged it and moved it to another room where my signal was poor.
Excellent value for money and a nice bit of kit - thoroughly recommend.
  • Overall 5*
  • Ease of use 5*
Low cost, simple and easy to use
Reviewed by Peter. Review Posted 15/07/2009
Having spent the best part of a day trying to configure a Linksys G router to talk with my Belkin Modem/Router without any success, I was fortunate to come across this range extender in my search.
There are not too many other N range extenders out there and reviews for other extenders all define how poor they are to set up.
Within 15 minutes of opening up the box, it was connected, configured and working perfectly.
The range is great, and now I have full access to the internet and network from my remote computer in the office in the garden.
  • Overall 5*
  • Ease of use 5*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
