Drobo, makers of the award-winning data storage products for businesses and professionals, offers a line of sophisticated yet easy-to-use and affordable storage solutions for small and medium businesses. Built on the proven BeyondRAID technology, Drobo delivers advanced capabilities such as thin provisioning and dual drive redundancy, usually reserved for more expensive enterprise solutions. Drobo SAN storage for business is designed to provide reliable and high performance storage to servers running business-critical applications such as back up, email, and server virtualization. Drobo B1200i connects seamlessly to your existing TCP/IP network and utilizes the industry-standard iSCSI protocol to provide simple, consolidated storage for your servers.
- Drobo SAN for Business B1200i - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- Gigabit Ethernet
- Host Channels
- 3
- Maximum LUNs
- 255
- Installed Devices / Modules Qty
- 12 (max)
- Supported Drives
- SATA-600 / SAS-2
- Built-in Devices
- Led panel
- Storage Controller
- SAS-2 (SATA 6Gb/s / SAS 6Gb/s)
- Hard Drive
- No HDD
- OS Required
- Microsoft Windows Vista (32/64 bits) SP1, Apple MacOS X 10.5.8 or later, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows Server 2008 R2 x64 Edition SP1, Apple MacOS X Server 10.5.8 or later, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Microsoft Windows XP (32/64 bits) SP1
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 43.61 cm x 55.5 cm x 13.21 cm
- 21.3 kg
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Led panel
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- Gigabit Ethernet
- Host Channels
- 3
- Maximum LUNs
- 255
Storage Controller
- SAS-2
- Channel Qty
- 12
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Max Storage Devices Qty
- 12
Hard Drive
- No HDD
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 3.5"
- 3 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-T (management) - RJ-45
- OS Required
- BeyondRAID technology
- Software Included
- Drobo Dashboard
- UL, TUV, CISPR 22 Class B, cUL, CB, ICES-003 Class B, MIC, AS/NZS 3548, RoHS, WEEE, BSMI CNS 13438, FCC Part 15 A, ACA, REACH, VCCI V-3
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 43.61 cm
- 55.5 cm
- 13.21 cm
- 21.3 kg
- 10 °C
- 35 °C
- 20 - 80%
