The Vigor 2830 series is DrayTek's flagship premium ADSL router/firewall family with support for professional features such as VLAN tagging and Gigabit Ethernet. Compatible with all variants of ADSL (including ADSLMax, ADSL2+ and Annex M) the Vigor 2830 can be used for cable-modem and leased line applications using its additional gigabit ethernet WAN port. A four port Gigabit switch on the LAN side provides high speed connectivity for your server or other local PCs, for the highest speed local data transfer. Security features include content filtering, web application controls and object based firewall management system.
- Draytek Vigor 2830n - wireless router - DSL - 802.11b/g/n - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, READSL
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- Concurrent VPN tunnels : 32 , NAT/ firewall sessions : 60000
- PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DHCP, DNS, DDNS
- Routing Protocol
- RIP-2, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI
- Firewall protection, DHCP support, NAT support, VPN support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, E-mail alert, print server, MAC address filtering, URL filtering, firmware upgradable, DDos attack prevention, wall mountable, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11e, IEEE 802.11n
- Power
- AC 230V
- 16.5 cm x 24.1 cm x 4.4 cm
- 2 years warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
- Authentication Method
- RADIUS, X.509 certificates
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
- LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB : 1 x 4 PIN USB Type A , WAN : 1 x ADSL2+ - RJ-11 , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- Power adapter - external
- Voltage Required
- AC 230V
- 18 Watt
- 16.5 cm
- 24.1 cm
- 4.4 cm
- CE, FCC, X.509
- 2 years warranty
- Service & Support Details
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 90 day warranty and is in good working order. You can find out the exact details about each product using the key below.
| Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
7LLJ 009549 Condition: this is a used item tested ok. |
£123.48 | |||||
Ref:
7LLJ 009553 Condition: This is a used item tested ok. please note there is no power supply with this one. |
£111.57 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
