The Vigor2830 is the latest generation of our flagship ADSL router/firewall range, winner of the PC Pro wireless router award for three years in a row. This latest series includes support for professional features such as VLAN tagging, Gigabit Ethernet and WiFi (ess models). The Vigor 2830's secondary WAN interface can be connected to other modems now or later (e.g. a second ADSL, BT Infinity or cable modem etc.).
Packed with features, the Vigor 2830 offers truly comprehensive ADSL connectivity and security.
Compatible with all variants of ADSL (including ADSLMax, ADSL2+ and Annex M) the Vigor 2830 can also be used for cable-modem and leased line applications using its additional gigabit ethernet WAN port. A four port Gigabit switch on the LAN side provides high speed connectivity for your server or other local PCs, for the highest speed local data transfer. Security features include content filtering, web application controls and new object based firewall management system.
Robust & Comprehensive Firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorised remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The latest ('Version 3') DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organisations. The Vigor 2830 now also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN. In addition, QoS (Quality of Service Assurance) can now be selectively applied to specific users.
IPv6 - Next Generation Internet Routing
The Vigor 2830 now supports IPv6 - the successor to the current IPv4 addressing system that has been used since the Internet was first created. IPv4 address space is full up and IPv6 allows for much more efficient routing and a larger address space. IPv6 is supported both from your own ISP, but if your ISP does not (yet) support IPv6, the Vigor 2850 also supports IPv6 broker/tunnel services to provide IPv6 access using either TSPC or AICCU via 3rd party IPv6 providers.
IPv6 on the Vigor 2830 provides the following features:
IPv6 support DrayTek Vigor 2830
Operation on any one of the WAN ports (ADSL, VDSL, Ethernet or 3G)
Connectivity to direct native IPv6 ISPs
Built-in tunnelling to 3rd party IPv6 brokers supporting TSPC or AICCU methods
Default stateful firewall for all IPv6 LAN Clients/Devices
DHCPv6 Client or Static IPv6 Client
DHCPv6 & RADVD for client configuration
IP Filtering Rules
QoS for IPv6 with DiffServ
Router Management over IPv6 (Telnet/HTTP) with IPv6 Access List
Simultaneous (concurrent) operation with IPv4 ("Dual-Stack")
Other router features are available on IPv4 only currently
Web Content Filtering
GlobalView Categories
The Content control features of the Vigor 2830 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or univeral. Using DrayTek's GlobalView service, you can block whole categories of web sites (e.g. gambling, adult sites etc.), subject to an annual subscription to the Globalview service, which is continuously updated with new or changed site categorisations or sites which have become compromised (such as infected with Malware). A free 30-day trial is included with your new router.
Triple-WAN Load Balancing & Backup
As well as the primary ADSL (WAN) interface, the Vigor 2830 features two other WAN connections. WAN2 is Ethernet (Gigabit) and WAN3 is a USB port for connection of a 3G modem. WAN2 (Ethernet) can connect to a second ADSL modem (e.g. Vigor 120), a cable modem or any other Ethernet-based Internet feed. The multiple WAN interfaces can be used either for WAN-Backup or load balancing.
WAN-Backup provides contingency (redundancy) in case of your primary ADSL line or ISP suffering temporary outage). Internet Traffic will be temporarily routed via the secondary Internet access. When normal services is restored to your primary ADSL line, all traffic is switch back to that.
If you don't have ADSL, the Ethernet WAN port can instead be used as your primary/only Internet connection (using NAT) so the same router can be used for either ADSL or Ethernet Internet connections.
The USB port provides Internet connectivity (main, backup or load balanced) by connecting to a compatible USB modem (or cellphone) for access to the high speed 3G cellular networks from UK providers such as Vodafone, T-Mobile, Orange, 3 and T-Mobile. If you don't have ADSL at all, the USB/3G access method can be used as your primary/only Internet connection, ideal for temporary locations, mobile applications or where broadband access is not available. In addition you can instead connect a compatible analogue modem to use analogue dial-up connections for failover in the event of your broadband failing.
2 Year Warranty
Robust and comprehensive firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorized remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organizations. The Vigor 2830 now also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN. In addition, QoS (Quality of Service Assurance) can now be selectively applied to specific users. The content control features of the Vigor 2830 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites, blocking IM/P2P applications or other potentially harmful or wasteful content. -
Triple-WAN load balancing and backup
As well as the primary ADSL (WAN) interface, the Vigor 2830 features two other WAN connections. WAN2 is Ethernet (Gigabit) and WAN3 is a USB port for connection of a 3G modem. WAN2 (Ethernet) can connect to a second ADSL modem, a cable modem or any other Ethernet-based Internet feed. The multiple WAN interfaces can be used either for WAN-backup or load balancing. WAN-backup provides contingency (redundancy) in case of your primary ADSL line or ISP suffering temporary outage). Internet traffic will be temporarily routed via the secondary Internet access.
- Draytek Vigor 2830Vn - wireless router - DSL modem - 802.11b/g/n (draft 2.0) - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DDNS
- Routing Protocol
- RIP-2, IGMPv2, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI
- VoIP Protocols
- SIP
- Telephony Interfaces
- 2 phone (FXS), 1 line (FXO)
- Firewall protection, DHCP support, NAT support, VPN support, load balancing, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, E-mail alert, print server, MAC address filtering, URL filtering, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n (draft 2.0)
- 24.1 cm x 16.5 cm x 4.4 cm
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
- Authentication Method
- RADIUS, X.509 certificates
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n (draft 2.0), FCC
- Status Indicators
- Port status, power, link/activity
Communications
- DSL modem
- ADSL2, ADSL2+
IP Telephony
- VoIP Protocols
- SIP
- Voice Codecs
- G.711, G.723.1, G.726
- IP Telephony Features
- Echo cancellation (G.168), Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer, gain control
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 2 x FXS - RJ-11 , Phone line: 1 x FXO - RJ-11
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- 10 Watt
- 24.1 cm
- 16.5 cm
- 4.4 cm
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
Get the most from your Router
DrayTek Rack Mount Bracket For Vigor 2830, 2850, 2920, 2930 | In Stock | £35.00 |
