Now with "DrayOS Firmware!"
Vigor 2760 provides connectivity to your PCs or other Internet-connected devices (laptops, tablets, games consoles, smartphones) via its built-in Gigabit ports, or using Wireless LAN (on 'n' models). The firewall helps protect your network from external threats, as well as the Vigor2760's built-in content filtering which gives you control over what and when your local users can access or download. For Wireless LAN usage, the Vigor2760n version supports multiple security methods, including strong encryption but also hardware-specific authorization and selectable client isolation (from each other).
The Vigor 2760 supports all variants of mass-market DSL technology available, so if you have ADSL today it will work with that, but when VDSL (FTTC) comes to your area later, you're ready, already. VDSL is available from BT under their 'Infinity ' service, currently providing downstream speeds of up to 160Mb/s (depending on local service). Other ISPs are also starting to introduce VDSL across the country so coverage continues to increase. You can also use 3G/4G networks.
The ideal DSL firewall/router
Vigor 2760 provides connectivity to your PCs or other Internet-connected devices (laptops, tablets, games consoles, smartphones) via its built-in Gigabit ports, or using Wireless LAN (on 'n' models). The firewall helps protect your network from external threats, as well as the Vigor2760's built-in content filtering which gives you control over what and when your local users can access or download. For Wireless LAN usage, the Vigor2760n version supports multiple security methods, including strong encryption but also hardware-specific authorization and selectable client isolation (from each other). -
Future-proofing just got easier
The Vigor 2760 supports all variants of mass-market DSL technology available, so if you have ADSL today it will work with that, but when VDSL (FTTC) comes to your area later, you're ready, already. VDSL is available from BT under their 'Infinity ' service, currently providing downstream speeds of up to 160Mb/s (depending on local service). Other ISPs are also starting to introduce VDSL across the country so coverage continues to increase. You can also use 3G/4G networks. -
Web content filtering
The content control features of the Vigor 2760 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists (a lit of allowed sites) or blacklists (a list of blocked sites), blocking IM/P2P applications or other potentially harmful or time-wasting content. This is particularly useful in the home, where children need to be protected, or workplaces where inappropriate sites may be a liability, security risk or harmful to productivity. Restrictions can be per user, per PC or univeral. Using DrayTek's GlobalView service, you can block whole categories of web sites (e.g. gambling, adult sites etc. ), subject to an annual subscription to the Globalview service, which is continuously updated with new or changed site categorizations or sites which have become compromised (such as infected with Malware). -
3G/4G cellular data & Network Attatched Storage (NAS)
The Vigor 2760 has two USB ports which can be used for 3G/3G modems, USB memory or a printer for shared access. You can connect a USB 3G/4G modem to the Vigor2760 and use the cellular networks (O2, EE, Vodafone, Virgin, 3) as your Internet connectivity. That can be your primary (only) connection, or the router can switch over to 3G in the case of ADSL/VDSL outage so that you're always connected. You can use your Vigor 2760 as a network attached storage (NAS) repository. This allows you to store files for local or remote users (anywhere on the Internet) to download - ideal for when you're on the move. You can also let users upload files - each remote user can have their own login and read-only or read-write FTP access to a preset directory. The Vigor 2760 has 40 Mb of memory built-in for NAS but you can add a USB memory stick for as much storage as you need.
- Draytek Vigor 2760Vn - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2+, VDSL2
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- VPN tunnels: 2 , UPnP sessions: 30 , NAT sessions: 20000
- PPTP, L2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, DDNS
- Routing Protocol
- IGMPv2, IGMP, MPOA
- Remote Management Protocol
- Telnet, HTTP, HTTPS, SSH
- VoIP Protocols
- SIP, RTCP, RTP
- Telephony Interfaces
- 2 phone (FXS), 1 line (FXO)
- Flow control, firewall protection, DHCP support, NAT support, ARP support, VLAN support, wake on LAN (WOL), IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, DiffServ support, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Dead Peer Detection (DPD), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, Multiple SSID support, hidden SSID, DNS proxy, 2T2R MIMO technology, IPv4 support, 3G/4G USB Dongle Support, anti-spoofing protection, Traffic Control, IP-MAC binding, policy based access control, DNS caching, IGMP proxy, Content Security Management (CSM)
- X.509, UPnP
- Power
- AC 120/230 V
- 12.5 cm x 18.2 cm x 4 cm
- 2-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, MPPE, AES, IKE, SHA-1, WPA, WPA2, PKI, WEP
- X.509, UPnP
- Flash Memory
- 40 MB
- Built-in Devices
- Led panel
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.997.1, ITU G.992.5, ITU G.993.1, ITU G.993.2
IP Telephony
- VoIP Protocols
- SIP, RTCP, RTP
- Voice Codecs
- G.711, G.723.1, G.729a, G.711u, G.711a, G.726, T.38, G.729b
- IP Telephony Features
- Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), call forwarding, call waiting, call hold, call transfer, message waiting, DTMF generation/detection, Calling Line Identification Restriction (CLIR)
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , Phone line: 2 x FXS - RJ-11 , Phone line: 1 x FXO - RJ-11 , Antenna: 2 x , USB 2.0: 2 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 16.3 Watt
- 12.5 cm
- 18.2 cm
- 4 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
