The devolo 9640 dLAN 550 WiFi HomePlug Network Kit with range+ Technology provides fast, high-performance Internet connections with significantly longer ranges. This devolo 9640 dLAN 550 WiFi HomePlug Network Kit uses your household electrical wiring to bring you the Internet to any room. Thanks to the intelligent WiFi Move Technology in the devolo 9626 dLAN 550 WiFi HomePlug Adapter, all terminal devices are also automatically connected to the network, giving you top performance WiFi reception for smartphones, tablets etc. in all rooms and on every floor. Along with its compact and unobtrusive design, the devolo 9626 dLAN 550 WiFi HomePlug Adapter provides a LAN port for one additional terminal device such as a smart TV.
Key features
- Kit includes 1 x devolo 9292 550 Duo+ and 2 x devolo 9626 dLAN 550.
- dLAN 550 WiFi brings the Internet to any corner of your home over the electrical wiring.
- Top performance WiFi reception for smartphones, tablets, etc. at speeds of up to 300 Mbps.
- Powerline connection over the electrical wiring at speeds of up to 500 Mbps.
- devolo range+ for even greater performance and extended range.
- LAN port lets you connect another Internet-compatible device (e.g. game console or smart TV) to the Internet.
- Compact design for convenient placement throughout the home, at any power socket.
- WiFi Move Technology can automatically connect multiple WiFi adapters to a single Wi-Fi network.
- Optimal WiFi reception throughout your home—entirely automated.
- devolo app helps you perfectly manage your personal home network to meet all your needs.
Intelligent WiFi Move Technology
Intelligent WiFi Move Technology provides even more freedom: Now, smartphones, tablets and laptops are automatically connected to the Internet - the best WiFi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place.
High Speed Data Transmission
High-speed data transmission at powerline speeds of up to 500Mbps and a fast Ethernet connection for connecting an additional network device such as Smart TV or game console to one of the HomePlug ports.
- devolo dLAN 550 WiFi - Network Kit - powerline adapter - Wi-Fi - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 1901
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), reset button, 2T2R MIMO technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901
- Power
- AC 230V (50 Hz)
- 6.8 cm x 4.1 cm x 6.8 cm
- System Requirements
- Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits)
- 3-year warranty
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 500 Mbps
- Max Range Open Space
- 300 m
- Selectable Channels Qty
- 13
- CSMA/CA
- Encryption Algorithm
- WPA, WPA2, 128-bit AES
- Status Indicators
- WLAN, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 4.4 Watt
- Cables Included
- 1 x network cable
- OS Required
- 6.8 cm
- 4.1 cm
- 6.8 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
