Use the dLAN 500 duo from devolo for the optimal entrance into your own world of home networking. The easy connection via household powerlines makes the Internet available in any room in no time. Two LAN ports on the adapter allow for two devices to be directly connected, such as a computer and network printer in the home office or Smart TV and a game console in the living room. The compact housing enables flexible and unobtrusive placement at any power outlet in your home. Of course, the home network can be expanded at any time with additional adapters. This way, the innovative dLAN technology brings the Internet into any room.
- devolo dLAN 500 duo - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), integrated power socket
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
- Power
- AC 230V (50/60 Hz)
- 5.5 cm x 4 cm x 11 cm
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- 3.5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 5.5 cm
- 4 cm
- 11 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
