dLAN® Powerline adapter for Internet and network connection via household power lines into any room - whether cabled or via WLAN. All devices in the room have an optimum connection
Easy and flexible set-up of WLAN zones - any power outlet is a WLAN access point
3 LAN ports for easily connecting cable-based devices such as PCs, printers, TVs or game consoles
Simple monitoring of the dLAN® home network with adapter status and display of the transmission rate via dLAN® Cockpit App
The integrated electrical socket ensures that no power outlet is lost! You can connect terminal devices and power strips directly to the adapter
Integrated mains filter ensures interference-free data transmission, even when multiple devices are plugged in
500 Mbps (gross) connection for fast data transmission in dLAN® Powerline home network, 300 Mbps (gross) in WLAN operation (IEEE 802.11n standard)
Power outlet adapter with integrated antennas (MiMo arrangement) for optimal transmitting power and flexible positioning
If WLAN is not needed, it can be switched off easily using a switch on the housing. In addition, automatic WLAN time control via software configuration is possible
Encryption for WLAN (WPS, WEP, WPA/WPA2) and dLAN® (AES) at the touch of a button
Thanks to the patented PowerSave technology which reduces the energy consumption automatically
Compatible with all dLAN® 200 and 500 AV adapters (HomePlug AV)
3-year manufacturer´s warranty, as unit is designed, tested and certified in Germany
- devolo dLAN 500 AV Wireless+ - Starter Kit - powerline adapter - 802.11a/b/g/n - wall-pluggable
- Powerline adapter - 3-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- MAC address filtering, Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n
- Power
- AC 230V
- 15.2 cm x 7.6 cm x 4 cm
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Encryption Algorithm
- WPA, WPA2, WEP
- Status Indicators
- Power, WAN, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
- LAN: 3 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
- Power Device
- Internal power supply
- Voltage Required
- AC 230V
- Included Accessories
- dLAN 500 AVplus Adapter
- Localisation
- United Kingdom
- OS Required
- 15.2 cm
- 7.6 cm
- 4 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
