In the dLAN 500 AV Wireless+, devolo combines all the features of a high-performance Powerline adapter in one housing. It integrated WLAN for an optimal connection to wireless terminal devices such as a smartphone or laptop, three LAN ports for connecting network-compatible devices. Using the integrated electrical socket, power strips and other devices up to 16 amps can be connected. Never has it been easier, faster or more secure to network wireless and stationary devices!
- devolo dLAN 500 AV Wireless+ - powerline adapter - Wi-Fi - wall-pluggable
- Powerline adapter - 3-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz / 5 GHz
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), integrated power socket, 2T2R MIMO technology, Direct Sequence Spread Spectrum (DSSS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV
- Power
- AC 230V (50 Hz)
- 7.6 cm x 4 cm x 15.2 cm
- System Requirements
- Apple MacOS X, Microsoft Windows Vista / XP / 7, Ubuntu, Microsoft Windows Vista / XP / 7 (64-bit versions), Windows 8 (32/64 bits), Windows 8 Pro, Windows 8 Pro 64-bit Edition
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Max Range Open Space
- 300 m
- CSMA/CA
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, FCC Class B certified, R&TTE, WEEE
- Status Indicators
- Power, wireless, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
- 1 x HomePlug AV - power CEE 7/7 , LAN: 3 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 9 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 7.6 cm
- 4 cm
- 15.2 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
