Dell Wyse Z90D7 Thin Client - DTS - 1 x G-T56N RAM 4GB Flash 16GB
Last Few Remaining
Clearance
Quicklinx: BP7QWS00 Mfr#: 909740-52L
Wyse Z90D7 is a super high-performance thin client for virtual desktop environments. Featuring a revolutionary, unified engine that eliminates performance constraints, the Z90D7 achieves incredible speed and power for the most demanding applications, rich graphics and HD video. Take a unit from box to productivity in minutes. The Z90D7 is an ideal thin client for the most demanding mix of virtual desktop or cloud applications.
  • Performance: advanced processing blows away everything
    It's fast. At the heart of the Wyse Z90 lies an engine, where all the major system elements - CPU cores, vector engines, and a unified video decoder for HD decoding tasks - live on the same piece of silicon. This design concept eliminates one of the fundamental constraints that limit performance. Whether you want the best 2D or 3D graphics, HD video, or the ability to embed custom Windows applications that execute right on the Z90, you'll have power to spare.
  • Ease of use: it's the thin client that does it all, without making you do it all
    The Wyse Z90 is based on Wyse-enhanced Windows Embedded, providing broad functionality for a dynamic world. The familiar user interface, integrated Windows Media Player, Internet Explorer, and full support for embedded Windows applications make the Z90 a powerhouse of capability whether you need a thin client for virtual desktop or cloud applications, a more-secure, solid state PC for custom applications, or a secure work from home station for telecommuters.
Dell Wyse Z90D7 Thin Client - DTS - G-T56N 1.65 GHz - 4 GB - flash 16 GB
Thin client - desktop slimline
1 x AMD G-T56N 1.65 GHz (Dual-Core)
RAM
4 GB DDR3 SDRAM
Hard Drive
Flash 16 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows Embedded Standard 7
4.7 cm x 22.5 cm x 20 cm
1.12 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years
Thin client
Product Form Factor
Desktop slimline
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD G-T56N
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB
DDR3 SDRAM
Hard Drive
Flash
16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Integrated
1 x DisplayPort , 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (1 in front) , 1 x microphone (1 in front) , 2 x serial , 1 x parallel , 1 x PS/2 keyboard
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
Power adapter
Operating System / Software
OS Provided
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
4.7 cm
22.5 cm
20 cm
1.12 kg
10 °C
10 - 95% (non-condensing)
BP7Q C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
