The Dell Wyse D90D7 is a high-performance thin client for virtual desktop environments. Featuring an unified engine that eliminates performance constraints, the D90D7 achieves outstanding speed and power for the most demanding VDI and embedded Windows applications, rich graphics and HD video. Take a unit from box to productivity in minutes. Just select the desired configuration and the D90D7 does the rest automatically - no need to reboot. The D90D7 is an ideal thin client for demanding virtual desktop or cloud applications.
Brilliant graphics
High definition multimedia experience leveraging hardware acceleration engine for various multimedia formats. -
Easy-to-manage
Hands-off management simplifies provisioning and updates. -
Green
Consumes less than 9 watts of power, reducing cost and carbon emissions.
- Dell Wyse D90D7 Thin Client - DTS - G-T48E 1.4 GHz - 4 GB - flash 16 GB
- Thin client - desktop slimline
- Processor
- 1 x AMD G-T48E 1.4 GHz (Dual-Core)
- RAM
- 4 GB (installed) / 4 GB (max) - DDR3 SDRAM
- Hard Drive
- Flash 16 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 6250
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7
- 4 cm x 18.5 cm x 17 cm
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Thin client
- Product Form Factor
- Desktop slimline
- Built-in Devices
- Speaker
Processor / Chipset
- CPU
- AMD G-T48E
- Clock Speed
- 1.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 4 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
Hard Drive
- Flash
- Capacity
- 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Integrated
- Data Link Protocol
- 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x DisplayPort
- Included Accessories
- Vertical stand
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE, cULus, EuP
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 4 cm
- 18.5 cm
- 17 cm
- 10 °C
- 40 °C
- 10 - 95% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
