See your work in its best light on the Dell UltraSharp 24 Monitor - U2414H. Its upscale design features an amazingly thin 6.05mm border around a 23.8" Full HD display that delivers impeccable images.
With this incredible clarity across an ultra-wide 178-degree viewing angle comes the ability to pivot left-and right up to 90 degrees, so you can create a multiple screen arrangement with near-continual imagery between two or more monitors.
World's thinnest border
Create a multiple screen arrangement with near-continual imagery between multi- monitors via the DisplayPort 1.2 (MST) connectivity port. -
Convenient connectivity
Bring your compatible mobile phones and tablets to life on a large screen with 2 HDMI (MHL) ports. Connect to projectors or other compatible devices through DisplayPort and mini-DisplayPort connectivity. -
Fast charging
A high-current USB 3.0 supplies twice the power for charging and powering compatible USB devices.
- Dell UltraSharp U2414H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 16 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976), 96% sRGB (CIE 1931)
- Input Connectors
- 2xHDMI (MHL), DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.91 cm x 18.5 cm x 35.58 cm
- 5.76 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI, WEEE, NFPA 99, ERP, EuP, China Energy Label, EDID compatible
- 3-year warranty
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Energy Class
- Class A+
- 24 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K, 10000K, 5700K
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass
- Black
- 53.91 cm x 18.5 cm x 35.58 cm - with stand
- 5.76 kg
- 2 x MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -6.5/+22
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
- Included Accessories
- Cable management cover
- Cables Included
- 1 x SuperSpeed USB cable - USB Type A to B , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16 W
- Power Consumption (Typical)
- 16 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 53.91 cm - depth: 18.5 cm - height: 35.58 cm - weight: 5.46 kg , Without stand - width: 53.91 cm - depth: 4.56 cm - height: 32.11 cm - weight: 3.61 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (3)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
Other bundles (1)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
