Dell SE2416H 23.8" 1920x1080 6ms VGA HDMI IPS LED Monitor
Quicklinx: BPVVWS00 Mfr#: 210-AFZI
With the expanded viewing area provided by an improved bezel, the Dell 24 Monitor offers an affordable, sleek design for everyday computing.
  • Stylish design
    Enjoy the elegance of thin, glossy bezels, a sturdy base, and easy to use buttons.
  • Video quality
    Optimize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution screen.
Dell SE2416H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
18.1 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 84% (CIE 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.66 cm x 17.99 cm x 42.31 cm
3.86 kg
Microsoft Certification
Compatible with Windows 7
RoHS
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class E
29 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Integrated cable management, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
55.66 cm x 17.99 cm x 42.31 cm - with stand
3.86 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
Stand
1 x VGA cable
RoHS
Security Slot Type
Kensington security slot
Input Voltage
18.1 W
18.1 kWh/1000h
Power Consumption (Max)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 55.66 cm - depth: 17.99 cm - height: 42.31 cm - weight: 3.86 kg , Without stand - width: 55.66 cm - depth: 5.5 cm - height: 33.01 cm - weight: 3.2 kg
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
BPVV C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
