Dell S2810dn Mono Laser Smart Printer
Quicklinx: BKG0WS00 Mfr#: 210-AEHH
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Ideal for small workgroups, the DellTM Smart Printer - S2810dn offers easy-to-use features, efficient performance and essential security at a low cost per page.
  • Efficient printing
    Print large and complex files effortlessly with an impressive 1GB of internal memory and save time with print speeds of up to 35 ppm (letter/A4).
  • Secure print release
    Keep sensitive documents private using the Secure Print feature. Print jobs are password protected and released easily when a valid user PIN is entered on the convenient LCD control panel's 10-digit keypad.
  • Private/Public Mail Box Print
    Store print jobs such as forms and templates in the built-in memory and print them when required. Stored jobs are easily released via the printer control panel.
  • Reduce effort and paper usage
    Cut paper costs and save up to 50% on paper usage with automatic two-sided printing.
  • Convenient mobile printing
    Print directly from a variety of mobile devices with Dell Document Hub app. This printer also supports AirPrint and Google Cloud Print, so you can print from virtually anywhere.
  • Easy printer monitoring
    The Dell OpenManage Printer Manager (OMPM) utility makes it easy to manage your network printers. Dell OMPM also enables the creation of printer status reports and fast deployment and driver updates.
  • Reduce PC software clutter
    Streamline driver management with the Dell Open Printer Driver (OPD), designed to reduce the huge workload of driver deployment and setting changes.
  • Essential security features
    Protect your device, information and network from unauthorized access with SNMPv3 encryption, IPSec and Transport Layer Security (TLS) protocols.
Dell S2810dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
12.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 22 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN
RAM Installed (Max)
1 GB DDR3 SDRAM
Language Simulation
PCL 5E, PostScript 3, PCL 6, Extensible Mark-up Language (XML), HBPL
Media Type
Envelopes, labels, plain paper, recycled paper, cover paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
500 - 3000 pages
Print server
Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Ubuntu 12.04 LTS (64-bit), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Ubuntu 12.04 LTS, Apple MacOS X 10.10, Red Hat Enterprise Linux Desktop 6 (32/64 bits)
1-year warranty
41 cm x 43.8 cm x 27.3 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0, LAN
1200 x 1200 dpi
Automatic Duplexing
Language Simulation
Media Handling
RAM
RAM Installed (Max)
1 GB
Technology / Form Factor
DDR3 SDRAM
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 216 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) , 1 x automatic - 50 sheets - 215.9 x 355.6 mm
Duty Cycle
40000 pages
500 - 3000 pages
Print server
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black)
GS, RoHS, WEEE
Security Slot Type
Kensington security slot
Power supply - internal
Frequency Required
50/60 Hz
Power Consumption Stand by
44 Watt
Power Consumption Sleep
7 Watt
Limited warranty - 1 year
10 °C
32 °C
10 - 85% (non-condensing)
41 cm
43.8 cm
27.3 cm
12.3 kg
BKG0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
