Watch your content come to life on the spacious Dell monitor with powerful dual speakers and enhanced entertainment features. Adjust your monitor for a custom fit with flexible viewing angles and multiple connectivity options.
Enhanced multimedia
This elegant Dell monitor makes your media come to life with enhanced visual and audio features for an immersive entertainment experience. Enjoy vivid, cinematic-quality pictures across an ultra-wide viewing angle with Full HD resolution. Let the powerful integrated speakers provide you with a captivating, rich audio experience. The ultra-narrow bezel improves dual-monitor and widescreen viewing, allowing the thin edges to be placed side by side for a virtually borderless appearance. -
Make it your own
Adjust your monitor for a custom fit with flexible viewing angles and multiple connectivity options. Stream audio directly from your smartphone or tablet, display content to your monitor and charge your devices at the same time with the convenient connectivity of an HDMI/MHL port. USB 2.0 ports allow you the freedom of connecting a mouse, keyboard or other peripherals to your monitor for a customized experience. View your content the way you want to with flexible viewing options that allow you to tilt your display forward or backward for a more comfortable angle. -
Environmentally-conscious design
Made with premium-quality materials, the S2715H is BFR/PVC-free and has an arsenic-free glass and mercury-free LED panel. -
Enhanced power management
Manage power consumption wisely. Dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell S2715H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 17 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.8 million colours
- Colour Gamut
- 72% (CIE 1931), 91% (CIE 1976)
- Input Connectors
- HDMI, VGA, MHL
- Speakers
- Integrated
- Tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.12 cm x 19.6 cm x 44.5 cm
- 6.16 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI
- Display Type
- Energy Class
- Class A+
- 25 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 6 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, sharpness, input select, colour temperature, aspect control, off timer
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free
- Black
- 61.12 cm x 19.6 cm x 44.5 cm - with stand
- 6.16 kg
Audio
- Speakers - stereo - integrated
- VGA , MHL / HDMI , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x USB cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- 17 W
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 61.12 cm - depth: 19.6 cm - height: 44.5 cm - weight: 6.16 kg , Without stand - width: 61.12 cm - depth: 4.61 cm - height: 36.15 cm - weight: 4.86 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
