Dell P2217 22" 1680 x 1050 5ms HDMI VGA LED LCD Monitor
Quicklinx: CQRVWS00 Mfr#: 210-AJCS
More productive than ever. The Dell P2217 brings a different level of productivity to the work place without sacrificing comfort and convenience.
  • Purposefully designed for comfort and convenience
    With a full range of adjustable features, slim borders and multiple connectivity ports.
  • Enhanced viewing experience
    Dell ComfortView and flicker-free feature make work less strenuous when viewing vividly clear visuals across an 5ms viewing angle.
  • Complete clarity
    Get excellent picture quality with consistent color representation across an 5ms viewing angle and a high dynamic contrast ratio.
  • Work comfortably with less stress
    Dell's ComfortView feature helps reduces harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled.
  • Auto mode and PowerNap
    Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
Dell P2217 - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class D
Energy Consumption per Year
48.5 kWh
Power Consumption (On mode)
13.3 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 84% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.34 cm x 18 cm x 36.74 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
RoHS, CECP, CEL
Display Type
Energy Class
Class D
48.5 kWh
Diagonal Size
22"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Pixel Per Inch
90
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
50.34 cm x 18 cm x 36.74 cm - with stand
HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), anti-theft protection
RoHS, CECP, CEL
Security Slot Type
Kensington security slot
Input Voltage
13.3 W
13.3 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.34 cm - depth: 18 cm - height: 36.74 cm , Without stand - width: 50.34 cm - depth: 5.03 cm - height: 33.04 cm - weight: 3 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
10 - 80% (non-condensing)
