Bring your own projector and present with confidence using a portable, easy-to-use projector featuring Intel Wireless Display (WiDi) and Miracast.
Easily connect and project
Wireless connections are a snap so you can focus on what matters the most - your material. -
Use with virtually any laptop or mobile device
Easily collaborate in conference rooms, classrooms and client sites with help from wide device compatibility. And with broad operating system support - you have the freedom to project from virtually any laptop, tablet or smartphone. -
Highly mobile, easily affordable
Give your staff the freedom to present wherever they need to with a highly portable and cost-effective projector. -
Expect a bright future
Project clearly with a powerful, 900-lumen LED light source. Help reduce IT maintenance costs with a reliable projector.
- Dell Mobile Projector M900HD - DLP projector - portable - WiDi / 802.11a/b/g/n wireless / Miracast Wi-Fi Display
- DLP projector - 720p
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 900 ANSI lumens
- Contrast Ratio
- 700:1 / 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- Intel Wireless Display (WiDi) / IEEE 802.11a/b/g/n wireless / Miracast Wi-Fi Display - MPEG-4, AVI, MJPEG, ASF, WMV, MOV, MKV
- Supported Memory Cards
- SD Memory Card
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 720p, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 142 Watt
- 23.2 cm x 16.4 cm x 4.3 cm
- 1.59 kg
- 1-year warranty
- Built-in Devices
- Speaker
- Networking
- 802.11a/b/g/n
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 900 ANSI lumens
- Contrast Ratio
- Image Size
- 76 cm - 203 cm
- Projection Distance
- 0.91 m - 2.4 m
- Throw Ratio
- 1.4:1
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- High-bandwidth Digital Content Protection System (HDCP), MobiShow technology, 16:10 aspect ratio support, Mercury-free illumination technology, upgradable firmware, Digital Zoom
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Video Interfaces
- HDMI, USB
- Video Modes
- SD Memory Card
- Digital Video Format
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n, WiDi, Miracast
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- Expansion Slots
- 1 x SD Memory Card
- 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A
- Included Accessories
- Carrying case, dust cover, wireless remote control
- Cables Included
- 1 x USB cable - 1.2 m
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 142 Watt
- Power Consumption Stand by
- 0.5 Watt
- 23.2 cm
- 16.4 cm
- 4.3 cm
- 1.59 kg
- Limited warranty - lamp - 1 year , Limited warranty - 1 year
- 5 °C
- 35 °C
- 0 - 80%
- Sound Emission
- 36 dBA
- Sound Emission (Economic Mode)
- 34 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
