Dell E2416H 24" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: BM8JWS00 Mfr#: 210-AFQH
A reliable and affordable 24" monitor with essential features that meet everyday office demands. It features great display quality at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort. Also it saves energy with power-efficient features.
  • Advanced screen performance
    View your applications, spreadsheets and more on 24" of 1920x1080 Full HD clarity, with 16.7 million colors, a high color gamut and a 160°/170° vertical and horizontal viewing angle.
  • Plug and view
    Compatible with legacy and current PCs via VGA and DisplayPort connectivity.
  • Mounting possibility
    Keep your desk clutter-free by mounting your VESA compatible monitor on the wall.
  • Tilt at will
    Work comfortably by tilting the monitor forward or backward.
  • Convenient controls
    Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
  • Reduced footprint
    The Dell monitor features PowerNap technology that reduces screen brightness or puts the monitor in sleep mode when it's not in use.
  • Environmentally friendly materials
    Your improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR) and PVC-free laminates, and it has more than large amount of post-consumer recycled plastics in its chassis.
Dell E2416H - LED monitor - Full HD (1080p) - 24" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 86% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.696 cm x 18 cm x 42.758 cm
3.6 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP
3-year warranty
Bundled with
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, Energy Gauge
56.696 cm x 18 cm x 42.758 cm - with stand
3.6 kg
Bundled with
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, VESA screw cover
1 x DisplayPort cable
DDC/CI, RoHS, CECP
United Kingdom
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.696 cm - depth: 18 cm - height: 42.758 cm - weight: 3.6 kg , Without stand - width: 56.696 cm - depth: 5.05 cm - height: 33.458 cm - weight: 2.91 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BM8J C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
