The PowerScan 8300 series readers' ergonomic enclosures are lightweight and well-balanced ensuring optimal operator comfort during scan intensive operations. Multiple good-read feedback features and a built-in metal tether hook for suspended applications ensure workplace productivity. The PowerScan 8300 series readers' superior reading performance is enhanced by Datalogic's patented Puzzle Solver technology for fast and accurate reading of standard, poorly printed and damaged bar codes.
The PowerScan 8300 series readers' mechanics have been developed and tested to withstand extreme environmental conditions maintaining consistent reading performance. Hard shocks, dust and water and adverse temperature conditions do not affect product performance or reliability.
The PowerScan 8300 series readers are offered with a full set of accessories and have multi-interface capabilities built in featuring the most popular interfaces. The Datalogic Aladdin configuration program provides user-friendly features that simplify the start-up procedure, even for inexperienced users.
- Datalogic PowerScan D8330 - barcode scanner
- Barcode scanner - handheld - keyboard wedge, RS-232, USB, wand - decoded
- Minimum Bar Width
- 7.5 mil
- Scan Element Type
- Visible laser diode
- Scan Speed
- 35 scan / sec
- Connectivity Technology
- Wired
- 295 g
Barcode
- Interface Type
- Keyboard wedge, RS-232, USB, wand
- Minimum Bar Width
- 7.5 mil
- Scan Element Type
- Light Source Wave Length
- 630-680 nm
- Scan Speed
- 35 scan / sec
- Max Working Distance
- 10 m
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 55
- Decode Capability
- EAN/JAN, Code 93, Code 39, Code 49, ISBT 128, ISBN, GS1 DataBar, Code 32, Codabar, Code 128, Code 11, Code 16K, UPC, MSI-Plessey, ISSN
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper
- Puzzle Solver Technology
- 1 x USB , 1 x RS-232 , 1 x barcode scanner - wand , 1 x keyboard wedge
- FCC Class A certified, EN55022 Class B, AS/NZS 3548, RoHS
- 295 g
- -30 °C
- 50 °C
- Drop Specification
- 2 m
