D-Link Wireless-N Dual Band Gigabit PoE Managed Access Point
Quicklinx: 627LWS00 Mfr#: DAP-2590/B
  • IEEE 802.11n (draft 2.0)
The D-Link DAP-2590 AirPremier N Dual Band PoE Access Point provides businesses with a solution for deploying next generation draft 802.11n local area networks (LANs). Designed specifically for business-class environments, such as large or enterprise corporations, this access point provides secure and manageable dual band wireless LAN options for network administrators.
The DAP-2590 AirPremier N Dual Band PoE Access Point allows network administrators to arrange a highly manageable and extremely robust dual band wireless network. All three detachable dual band antennas supply optimal wireless coverage in either 2.4GHz (802.11g and draft 2.0 802.11n) or 5GHz (802.11a and draft 2.0 802.11n) frequency bands. Enclosed in a plenum-rated metal chassis, the AirPremier N Dual Band PoE Access Point adheres to strict fire codes for placement in air passageways. For advanced installations, this high-speed access point has integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
The DAP-2590 delivers reliable wireless performance with maximum wireless signal rates of up to 300Mbps in either the 2.4GHz or 5GHz wireless band. Support for the Wi-Fi Multimedia (WMM) Quality of Service feature, makes it an ideal access point for audio, video, and voice applications. Additionally, this access point supports load balance features to ensure maximum performance.
D-Link DAP-2590 AirPremier N Dual Band PoE Access Point with Plenum-rated Chassis - radio access point
Radio access point
External - indoor
United Kingdom, Ireland
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Virtual interfaces (VLANs): 8
Power Over Ethernet (PoE) Supported
PoE
16.5 cm x 18.5 cm x 3.5 cm
0.76 kg
Radio access point
Ruggedized Design
Indoor
16.5 cm
18.5 cm
3.5 cm
0.76 kg
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Status Indicators
Power, link/activity
Load balancing, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Network Access Protection (NAP)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Aerial
Antenna
External detachable
Antenna Qty
3
1 x 1000Base-T - RJ-45
Mounting Kit
Included
FCC Class B certified, C-Tick, cUL, IC
PoE
External power adapter
10 - 90%
Resources
The following resources are available for the D-Link Wireless-N Dual Band Gigabit PoE Managed Access Point
