D-Link PowerLine AV 500 Wireless N Mini Extender
Quicklinx: 987ZWS00 Mfr#: DHP-W310AV/B
  • IEEE 802.11n
The PowerLine AV 500 Wireless N Extender DHP-W310AV, allows you to extend your existing home network to enjoy high-speed and reliable connectivity throughout your home. By combining both PowerLine and wireless technology, it allows you to extend and create wireless networks, with the latest HomePlug AV and wireless N standards, where it was not possible before. Using your existing electrical wiring, no additional wires are necessary to extend your network.
The PowerLine AV 500 Wireless N Extender features both wireless and PowerLine. This allows you to benefit from PowerLine networking, compliant with the HomePlug AV standard that uses your existing home electrical wiring to extend your home network. The wireless ability allows you to increase the area in your home where you can use your wireless devices.
  • Data transmission over electrical wiring
    The D-Link DHP-W310AV PowerLine AV 500 Wireless N Mini Starter Kit, compliant with the HomePlug AV standard, uses your home's existing electrical wiring to create a network or extend your existing network. It turns every power outlet into a potential network connection to access digital media devices, game consoles, print servers, computers, and network storage devices throughout your home. Additionally, Wireless N provides high speed transfers without the need for unsightly network cables.
  • Faster wireless speeds and wider operational range
    The Wireless N technology incorporated into this PowerLine product offers increased speed and range beyond standard 802.11g technology. Initial wireless setup can be accomplished quickly, thanks to a convenient setup wizard. WPA and WPA2 encryption keep your network traffic safe and secure.
  • Ideal for bandwidth intensive applications
    This kit is capable of delivering PowerLine AV 500 data transfer rates of up to 500 Mbps and Wireless N speeds of up to 300 Mbps. This rapid transmission speed makes it ideal for bandwidth-intensive applications, guaranteeing smooth HD video streaming, clear VoIP calls, and lag-free online gaming experiences. In addition, it prioritizes Internet traffic, ensuring that multimedia applications do not experience glitches while web surfing and downloads are in progress. This device provides ample network bandwidth, enabling digital home consumers to tap into existing electrical wiring for high-quality multimedia streaming.
  • Convenient setup and secure operation
    The DHP-W310AV plugs directly into a power outlet, and does not require any additional cables. Extend your home network by connecting multiple devices to the farthest corners of your home via Ethernet cable or Wireless N. For convenient setup, wired or wireless encryption keys can be quickly configured with the push of a button on top of the device. The adapter implements 128-bit AES data encryption to protect your network from unauthorized access. With hassle-free 'plug and play' installation, the DHP-W310AV is an ideal solution to create a wall-to-wall home network.
D-Link PowerLine DHP-W310AV - powerline adapter Wi-Fi - desktop
Powerline adapter
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
128-bit encryption, 64-bit encryption, auto-uplink (auto MDI/MDI-X), IPv6 support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901
9 cm x 6.5 cm x 5 cm
Microsoft Windows Vista / XP / 7
Powerline adapter
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
500 Mbps
Encryption Algorithm
WPA, WPA2, 128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, UL, FCC, RoHS, LVD
Status Indicators
Port status, power
Line Properties
Line Coding Format
OFDM
1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
9 cm
6.5 cm
5 cm
10 - 95% (non-condensing)
