The DKVM-2KU 2-port mini KVM (Keyboard, Video and Mouse) switch allows you to easily control 2 different PCs from a single set of keyboard, mouse, and VGA monitor, and to share a USB device with 2 PCs. It includes 2 sets of built-in cables for ready connection to 2 PCs.
If you have 2 PCs and need to use them at the same time, the DKVM-2KU saves you the money and space by allowing you to control your 2 computers from a set of keyboard, monitor and mouse. Or, you may have a better, bigger monitor and want to connect both PCs to it, the DKVM-2KU allows you to do this. 2 sets of cables are attached to the KVM switch ready for use, dispensing you of the need to prepare separate cables and connect them to the switch.
The DKVM-2KU supports VGA, SVGA, and MultiSync monitors at up to 2048 x 1536 resolution at 72Hz refresh rate. Support for Microsoft IntelliMouse is provided. There is also a control button located on the front panel that allows you to switch between the PCs.
A USB 2.0 port is built into this KVM switch to allow connection to a USB-supported device or a USB hub. This allows you to share your USB printer, scanner, card reader or other devices among the 2 connected PCs.
- D-Link DKVM 2KU - KVM / USB switch - 2 ports - desktop
- KVM / USB switch - 2 ports - PS/2
- Enclosure Type
- Desktop
- Ports
- 2 x KVM / USB
- KVM Users Qty
- 1 local user
- USB 2.0
- 10.4 cm x 6.2 cm x 2.8 cm
- 0.57 kg
- Enclosure Type
- Desktop
- Ports
- 2 x KVM / USB
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 2048 x 1536
- USB 2.0
- Status Indicators
- Port status
- Display / video : 2 x VGA - 15 pin HD D-Sub (HD-15) , Keyboard : 2 x generic - 6 pin mini-DIN (PS/2 style) , Mouse : 2 x generic - 6 pin mini-DIN (PS/2 style) , USB : 2 x 4 PIN USB Type A , Mouse : 1 x generic - 6 pin mini-DIN (PS/2 style) - 1 , Keyboard : 1 x generic - 6 pin mini-DIN (PS/2 style) - 1 , Display / video : 1 x VGA - 15 pin HD D-Sub (HD-15) - 1 , USB : 1 x 4 PIN USB Type A - 1
- 10.4 cm
- 6.2 cm
- 2.8 cm
- 0.57 kg
- Cables Included
- 2 x keyboard / mouse / video / USB cable - 1.8 m
- FCC Class B certified, C-Tick
- 0 °C
- 40 °C
- 0 - 80%
