D-Link 21Mbps HSPA+ USB Adapter
Quicklinx: 9H4DWS00 Mfr#: DWM-157
The DWM-157 3G HSPA+ USB Adapter allows you to enjoy a fast mobile broadband connection on your notebook or computer, whether you are at home, in the office, or traveling. The device allows you to connect to any 3G mobile broadband networks worldwide. With a fast and convenient mobile connection at your fingertips, you don't have to worry about losing your Internet connection when you leave home.
  • Global mobile broadband
    The HSPA+ mobile protocol lets you take your broadband connection with you wherever you go.
  • Plug and Play
    Built-in drivers and software provide immediate access to data and SMS functions.
D-Link DWM-157 - wireless cellular modem - 3G
Wireless cellular modem - USB 2.0
External
Max Transfer Rate
21.6 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+
Apple MacOS X 10.4 or later, Microsoft Windows Vista / 2000 / XP
2.65 cm x 8.25 cm x 1.45 cm
External
Modem
Bus
USB 2.0
Max Transfer Rate
21.6 Mbps
Antenna
Internal
Antenna Qty
1
Supported Flash Memory Cards
microSD
SIM Card Supported
Regular (mini-SIM) x 1
2.65 cm
8.25 cm
1.45 cm
-10 °C
55 °C
