D-Link's DGS-1210 series features D-Link Green technology. Equipped with 16 10/100/1000Mbps ports including 4 combo 10/100/1000BASE-T/SFP ports, the series integrates advanced management and security functions that provide performance and scalability. Management options for the switches include SNMP, Web Management, SmartConsole Utility, and compact command lines. The series also supports ACL filtering and D-Link's Safeguard Engine. Furthermore, the DGS-1210 series uses auto voice VLAN, ensuring higher priority for voice traffic. The DGS-1210-16 comes with a fanless design in 19" metal cases. These fans are set to low speed by default and will automatically switch to high speed once the temperature threshold is reached.
- D-Link Web Smart DGS-1210-16 - switch - 16 ports - Managed - desktop
- Switch - 16 ports - Managed
- Enclosure Type
- Desktop - 1U
- Ports
- 16 x 10/100/1000 + 4 x shared SFP
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, HTTP, TFTP
- Flow control, full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
- Power
- AC 120/230 V ( 50/60 Hz )
- 44 cm x 21 cm x 4.4 cm
- 2.9 kg
- Enclosure Type
- Desktop - 1U
- Ports
- 8K entries
- Authentication Method
- RADIUS
- RAM
- 512 KB
- Built-in Devices
- Led panel
- Status Indicators
- Link activity, port transmission speed, power, link OK
- 16 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC)
- Power Device
- Power supply - internal
- Voltage Required
- 17.4 Watt
- 44 cm
- 21 cm
- 4.4 cm
- 2.9 kg
- MTBF
- 799,491 hour(s)
- FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A
- 0 °C
- 40 °C
- 10 - 95%
