Cyberpower EX Series EX850E 850VA UPS (with UK Plug)
Quicklinx: 949GWS00 Mfr#: EX850E-UK
Featuring with surge protected RJ11/RJ45 port, the EX series UPS is ideal for home entertainment systems and SOHO networks with its full protection against surge/spikes and power abnormalities. With EMI/RFI filters eliminating line noise or disturbances, it could supply reliable backup during power interruptions, brownouts and blackouts. The space-wise tower design could be placed horizontally or vertically to make the most your work space!
CyberPower EX Series EX850E - UPS - 490 Watt - 850 VA
UPS - external
3 kg
United Kingdom
Output Voltage
AC 230 V ± 5%
Power Capacity
490 Watt / 850 VA
Input Connectors
1
Output connectors
1 (surge) , 2 (UPS and surge)
Lead Acid - 7 Ah
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
2 min at full load
USB
11 cm x 30.9 cm x 8.4 cm
UPS - external
Battery Enclosure Type
Internal
United Kingdom
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
490 Watt / 850 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Voltage Provided
12 V
7 Ah
Run Time (Up To)
2 min at full load , 7 min at half load
Recharge Time
8 hours
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable - integrated , Phone cable - external , USB cable - external
LED indicators, GreenPower UPS Technology, overload protection
RoHS
Software Included
PowerPanel Personal
0 - 90% (non-condensing)
11 cm
30.9 cm
8.4 cm
3 kg
