Crucial 16GB (2x8GB) DDR3-1600 1.35V SO-DIMM Memory
Quicklinx: 87NPWS00 Mfr#: CT2KIT102464BF160B
In short, 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. 204-pin SODIMMs are currently available in PC3-8500 (DDR3 1066MHz) and PC3-10600 (DDR3 1333MHz) speeds.
To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets.
SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.18 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM's printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
  • Make everything on your computer faster
    Memory is a component in your computer that allows for short-term data access. Since your system's moment-to-moment operations rely on short-term data access - loading applications, browsing the Web or editing a spreadsheet - the speed and amount of memory in your system plays a critical role. Load apps in seconds by increasing the speed of your memory and installing more of it.
  • Multitask with ease
    If you're like us, you use your computer to do lots of things at once. You might be editing a document, while also looking at pictures and browsing the Internet. This naturally leads to a performance problem: every app you're running requires memory and competes for a limited pool of resources. Overcome this by installing high-density modules in each memory slot for seamless multitasking.
  • Extend battery life
    One of the most important aspects of laptop performance is battery life. By upgrading your memory, you can potentially take advantage of lower voltage modules - and increase energy efficiency by up to 40% when using the latest memory technology. 1 What's more, by simply installing more memory, you'll reduce the number of times your system has to access the hard drive (paging). Less paging means tasks are done faster - using less battery power.
  • Maximize the value of your system
    At a fraction of the cost of a new system, a memory upgrade is one of the most affordable ways to increase performance. Get more out of your laptop by giving it the resources it needs to perform.
Crucial - DDR3L - kit - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.35 V
