The perfect partner to the ZiiSound D5x or ZiiSound D3x
If room-filling sound is not enough and you want to add the impact of theater-like bass, you'll almost certainly want a subwoofer to accompany your ZiiSound D5x or ZiiSound D3x wireless Bluetooth® modular speaker. Exclusively designed for use with the ZiiSound D5x or ZiiSound D3x - and complete with sleek matching looks, the ZiiSound DSx wireless subwoofer adds bass enhancement to any speaker configuration1, anywhere in your home2.
Featuring our signature SLAM™ (Symmetrically Loaded Acoustic Module) technology, the ZiiSound DSx delivers thunderous output from three drivers enclosed in a portless casing. Tear the roof down with a rocking party in your home with up to three ZiiSound D5x or D3x speakers wirelessly connected to the ZiiSound DSx subwoofer. Or, if you seek personal movie-watching time with loved ones, the addition of ZiiSound DSx easily gives that level of cinematic bass to your favorite blockbuster show.
A simple, yet powerful upgrade
Designed exclusively for use with the ZiiSound D5x or ZiiSound D3x, the ZiiSound DSx wireless subwoofer delivers deep, tight bass that complete a full range of audio for a truly breathtaking listening experience. Click here to see an illustrated step-by-step guide on how to link the ZiiSound DSx with the ZiiSound D5x in mere seconds.
For just about any need
Be it additional 'oomph' needed to inject and liven up a party or much-needed realism for all the explosions in the latest action movie, the ZiiSound DSx provides that extra punch.
Place it virtually anywhere
Even in the largest of rooms, the ZiiSound DSx will fire away its heart-thumping lows from just about anywhere. It works up to 30 meters from the primary ZiiSound D5x or D3x speaker unit, measured in unobstructed space.
Spectacular power
Featuring Creative SLAM™ (Symmetrically Loaded Acoustic Module) technology, the compact subwoofer delivers a thunderous output. This portless design is extensively tuned and utilizes a master driver and dual pressure drivers housed in a highly compact inert enclosure. The end result? Quick transient response of a small driver together and high-output capability and deep bass extension of larger drivers.
1 The ZiiSound DSx wireless subwoofer will work with up to either three units of ZiiSound D5x or three units of ZiiSound D3x speakers. It will not work with a mixture of ZiiSound D5x and ZiiSound D3x units.
2 At a distance of up to 30 meters, measured in open space.
The ZiiSound DSx wireless subwoofer delivers deep, tight bass that complete a full range of audio for a truly breathtaking listening experience. -
Be it additional 'oomph' needed to inject and liven up a party or much-needed realism for all the explosions in the latest action movie, the ZiiSound DSx provides that extra punch. -
Even in the largest of rooms, the ZiiSound DSx will fire away its heart-thumping lows from just about anywhere. -
Spectacular power
Featuring Creative SLAM (Symmetrically Loaded Acoustic Module) technology, the compact subwoofer delivers a thunderous output. This portless design is extensively tuned and utilizes a master driver and dual pressure drivers housed in a highly compact inert enclosure.
- Creative ZiiSound DSx - subwoofer - wireless
- Product Type
- Subwoofer
- Speaker Type
- Active
- Amplifier
- Integrated
- 22 cm x 22 cm x 29 cm
- 4.6 kg
- Product Type
- Subwoofer
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Transmission Range
- 30 m
- Power Source
- AC power adapter
- 22 cm
- 22 cm
- 29 cm
- 4.6 kg
