Creative Woof 3 Micro-sized Bluetooth Speaker - Crystallite Blue
Quicklinx: C3V2WS00 Mfr#: 51MF8230AA002
The new Creative Woof3 Bluetooth speaker delivers sonic goodness in the size of a cup. Feel the action of your music rumble from the oversized bass radiator and hear your favorite musician's true potential come to life. Make Woof3 your perfect travel companion wherever you go.
  • Tiny companion that travels wherever you go
    The Woof3 delivers big sound with bass you can feel. It neatly fits the palm of your hand and shaped like a compact cup that's easy to grab and go. In fact, this micro-sized Bluetooth MP3/FLAC speaker was designed with portability in mind - from the palm-sized form factor to the long battery life to the multiple connectivity options for audio playback. It is an all-in-one, full-featured Bluetooth MP3/FLAC speaker that's perfectly sized for life on the go.
  • Palm-sized wonder
    The Woof3 is equipped with a powerful 45mm driver that delivers well-balanced audio in your hand. Don't let its size fool you. This palm-sized wonder produces big sound for its size, thanks to the oversized bass radiator. With up to six hours of playtime on a single charge, you can roam free with the Woof3 everywhere!
  • Plenty of ways to play your music
    Connect with your favorite music with four input options. The Woof3 checks your list of essentials a portable speaker needs to have.
  • Bluetooth connectivity
    Pair your smart devices with the Woof3 via Bluetooth. Enjoy different levels of convenience with built-in music control buttons to play, pause, skip tracks and adjust the volume of your audio.
  • Integrated MP3/FLAC player
    The microSD slot makes a great playback option if you wish to conserve your smartphone's battery life. Simply insert a microSD card storing your favorite songs and press the play button to enjoy. Two music players in one microSD slot. Enjoy the best of both worlds from mainstream formats such as MP3/ WMA, to lossless high quality formats such as WAV/FLAC/APE - all neatly packed in one slot. Plus, it is a microSD card reader for transferring your music, video, and personal data between your microSD card and your computer.
  • USB Audio
    Connect the Woof3 to your PC/Mac with the included micro USB cable. It will function as a USB audio device that ensures lossless digital audio playback. Plus, you can charge the speaker simultaneously.
  • AUX-in
    Put an old school charm in the music you love. Connect your analog devices to the Woof3 using the 3.5mm AUX-in cable.
  • A speakerphone in a speaker
    With a built-in microphone, the Woof3 intelligently switches between your voice calls and music. So you won't have to miss another call again.
Creative Woof 3 - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
USB-host, flash memory card
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, MP3, FLAC, APE (Monkey's Audio)
Blue
Built-in Decoders
SBC decoder
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
6.5 cm x 6.8 cm x 7.5 cm
237 g
Hands-Free Function
Microphone
Enclosure Colour
Blue
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Built-in Decoders
SBC decoder
Audio Formats
Controls
Power on/off, volume, call answer, play/pause, next track, previous track
Speaker System Details
Driver Details
Speaker: full-range driver - 1.77" , Portable speaker: Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
USB to micro-USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
500 mAh
Run Time (Up To)
6 hour(s)
6.5 cm
6.8 cm
7.5 cm
237 g
