Following the success of its predecessor, the Creative T6 Series II Signature Series 2.1 wireless sound system is now back with a bigger bang! The T6 Series II continues to stay true to delivering high-quality wireless audio, giving you the most compelling experience for your movies, games and music that is sure to rock you out of your seat with its deep, tight bass!
The speaker system connects quickly and effortlessly to any compatible stereo Bluetooth device, and is aptX-enabled for streaming high-quality, lag-free wireless audio. You get to have the audio experience your way - focused stereo or 5.1 surround sound - with Creative's Swivel-Speaker-Array satellites and a powerful SLAM subwoofer incorporated in its compact design, even via a USB connection. The chrome finishing on the top and base of the satellites further exudes the sophistication of the speaker design. Enjoy total convenience with the included remote control and the wired volume control pod. Via the control pod, you may also explore other connectivity options - AUX-in and headphone connectors.
Compatible with all stereo Bluetooth devices
Simply connect your Bluetooth stereo devices wirelessly to the speaker system and forget the hassle of wires, you are all set for high-quality audio. -
High-performance wireless audio
The aptX audio codec ensures high-quality Bluetooth audio playback with its superior low-latency Bluetooth connectivity. Seamless wireless audio is now a dream come true. -
Transform stereo to surround sound
With the innovative swivel-speaker-array design, you can switch from stereo to surround mode easily by rotating the top portion of each satellite speaker. -
Specially-designed powerful subwoofer
The powerful Creative SLAM subwoofer is tuned to perfection to bring you realistic heart-thumping lows for a completely engaging gaming or movie experience. -
Audiophile-grade drivers
Two high-end drivers on each satellite bring you full-bodied mids and soothing highs for a pleasant all-rounded audio experience. -
Wall-mountable satellites
The speaker system's satellites can also be wall-mounted, making them ideal for TV speakers in the living room. Simply remove the detachable satellite desktop stands and they're ready to be mounted. -
Convenient digital control pod
The handy all-in-one digital control pod gives you easy access and control over the speakers' functions. Select the audio source (Bluetooth, USB or AUX-in), adjust the volume or initiate Bluetooth pairing. For private listening, you can also output audio to headphones. -
IR remote control
Control your speakers from across the room with the included IR remote. Select the audio source, adjust the volume or control music playback with ease.
- Creative ZiiSound T6 Series II - speaker system - wireless
- Product Type
- Signature - speaker system - 2.1-channel
- System Components
- Transmitter, 2 speakers, subwoofer
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 2 x satellite speaker , 1 x subwoofer
- Product Type
- Speaker system - 2.1-channel
Speaker System
- Series
- Signature
- System Components
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Controls
- Subwoofer volume control, volume
- Interface Type
- USB
- Additional Features
- aptX Bluetooth technology, Swivel-Speaker-Array design
- Speakers Included
- 2 x satellite speaker - wired , 1 x subwoofer
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , USB (4 PIN USB Type B) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, USB cable, remote control, Bluetooth audio transmitter, IR remote control
- Remote Control
- Remote control
- Power Source
- USB
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.5 cm x 8.5 cm x 22.5 cm / 860 g , Subwoofer: 24 cm x 32 cm x 22 cm / 4.86 kg
